- Feb 18, 2013
- 453
- 294
Its been a while since my last post and I have to admit to being very close to chucking in the towel, I abandoned the project for a month as I was close to throwing it in the bin.
However, the rest did me good and I have learnt a few things about engine construction over the last few weeks.
I had always suspected the compression wasn't good enough and after chatting to a colleague who races two stroke motorcycles I decided to follow his advice and remake the pistons and rings. I went a stage further and made the pistons with two separate ring grooves as opposed to the plans two rings in one groove.
This meant making the pistons 1 mm longer to accommodate the second groove and hence a spacer was required to prevent the piston hitting the head.
The piston was made a closer fit, half thou under the bore diameter. The rings were made size to the bore and lapped in an identical bore to the cylinder.
I had discovered that as perfect as the ring may be, when spragged to give the gap it does not form a true circular contact when fitted. I think this was the crucial thing affecting compression and was born out by the results of the new method as I now had decent compression and a good bounce on the propeller.
Individually both cylinders now run fine on their own and starting is much much easier. However, put together I cannot get any life out of it and suspect I am not going to be able to hand flick start this beast. There may also be insufficient inertia in the prop so I will try a larger item.
Interestingly, the engine is very sensitive to the glow plug type. OSF 4 stroke plugs are a bit borderline and the engine really starts well on an Idle bar plug 'Taylor Made' brand so I will probably stick with those.
Hopefully I will get this twin running soon!!
