- Feb 18, 2013
- 453
- 294
I have not had much time to progress far with this project but today I had a go at making the cams. In the original article the cams were pretty much hand filed and I really didn't fancy that. I pondered on making a cam grinder but then decided to go the eccentric turning route as per the Edgar T Westbury method.
My turning fixture was hurriedly made but at least I knew the offset was ok despite hacksawing the clamp details!
This process is very slow, turn a bit and then rotate the cam 5 degrees or so each step. The cam blank pair is Loctited to a temporary shaft and will come off when I finally heat treat them.
All in all it took 1.1/2 hours to turn the two cam part.
