Grasshopper here. I got interested in vederstein's 2 cylinder engine. In due course, I found he only lives 6 miles from me. We got in contact, visited and I decided to build one of my own. His plans are on this site. I wasn't comfortable making the cylinders out of bar stock, so he poured a couple for me. Here are pictures of my progress so far. The cylinders are roughed out, the piston, piston rod and cross heads are finished. Also the cylinder glands and cross head frames
. The engine block has been the fun one. Circumstances were such that I had to start with a 5 inch diameter, 5 inch long block of aluminum. I turned one end with enough length to use as a knob for clamping in the lathe chuck. Then it was turning and hogging out the innards. You can see the pile of aluminum shavings you end up with. The block is in the dividing head to shave the lands for the cross head frames and cylinders for attachment.
