So on simpler cam profiles with (base circle > flat > nose radius) profiles, I believe like the Cirrus, flat bottom tappets would seem to have a few disadvantages: the potential for the edge digging into the cam as its rising, almost like a lathe tool. Potential for timing jumps as its transitions from flat to edge vs rounded tappets that kind of ramp a bit smoother into the cam profile. It obviously 'works' as you say. Maybe rounding those little buggers is not as easy as simply drawing them & thts more the issue? How did you do yours BTW?
When I say "no wear" obviously the correct answer is actually very slight "acceptable" wear. Less wear than I anticipated.
On the Cirrus, the diameter of the tappet bases is quite large relative to the cam. Here are the pictures. Note the cam shows some shine on portions of the nose, but as this cam was cut with an end mill and profiled by hand, there were bound to be high sections which wear first, and as it wears, surface contact improves. I think with any model IC engine, there's going to be some run-in time where the valve clearance will need to be adjusted more than once, to take up this initial wear.
The tappet bases don't even show much of a shine.
The Hodgson - the tappets had a full hemisphere made of A2 steel. Each of these now has a polished, flattened profile on the tip that measures perhaps 0.020" across. A better choice than a hemisphere profile might be having the tappets chamfered first, say 45 degrees, and then simply smoothing the remaining small diameter at the tip somewhat, so a larger surface rides the cam rather than a theoretical point.
Also, I think it's important to make the cam harder than the tappets, causing more wear on the tappets vs. the cam. Tappets are a lot easier to replace in the future than cams.
In retrospect, I wish I had engineered roller tappets using tiny instrument ball races, with the tappets keyed to their bushings. 1/8" square stock would do the trick, with each set of tappet bushings being one piece and pressed into the crankcase.
I freely admit to having only a basic knowledge of cams, cam profiles, and the performance changes that can result. I was far more into materials, how they wear, and getting basic, reliable performance was the goal from day one. After digesting a half-dozen cam articles on how to wring the very last joule of energy out of an IC engine, I was a bit discouraged, until I followed the deHavilland Cirrus 1/6th scale build in Strictly IC; saw that he milled the cams, polished by hand, and I understood that if all I wanted was a runner, not a race engine, it's not all that critical.
