The final step is to heat treat. I take the camshaft and wrap it up in wire as shown below, I then make a slurry of isopropyl alcohol and boric acid. I heat the camshaft and dip it in the slurry, reheating and dipping a few times until I have a nice coating of boric acid on the part. Then I heat it to bright red hot and quench in oil.
Below is the part after quench, it is free of scale. I boil up some water and rinse off the boric acid.
Finally I do a file scratch test. The file glides off the new part without making a mark, but when I do the same test on the old one, the file cuts easily. This notch is indicated by the red circle below on the old part.
Well that's it. I'll call 'er done.
As Joe Pie says, "I'm out."
