- Jan 17, 2009
- 1,081
- 281
The maximum amount of heat generated is ultimately related to the motor power.
A 5 HP lathe roughing heavy cut needs coolant but a 1/2 HP rarely demanding top power from the motor does not generate enough heat to bother.
Model engineering involves mostly light cutting trying to hit a dimension. Cutting oil will improve finish, reduce heating and add a modest cooling. That is all I ever need and use.
For critical parting or deep grooving (like cylinder fins) I have rigged a gravity dribble tube mounted on top of the tool post, adjustable and orientable. A milk bottle with transmission fluid on a high shelf, hoses and a needle valve. The bottle has a tight cap with an additional air hose, I blow into to start the siphoning, I use my compressed air but not directly or the bottle will explode, just direct the nozzle toward the tube.
The transmission fluid collect on the lover point of the chip pan where a fitting and a hose route the fluid to a receiver bottle, once a year I may need to transfer from receiver to the high tank.
