vederstein
Must do dumb things....
- Feb 26, 2011
- 932
- 776
On my first attempt at the crankshaft, I used bits and pieces I had laying around. The truth is, I entirely forgot I purchased material to make the crank. The first one sucked anyway.
I'm amazed by the folks that turn a crankshaft from a single piece of barstock. It looks very difficult and I've always been to intimidated to try it. This engine is no different. I make my cranks from built up pieces.
The round pieces are just pieces of 1/2" roundstock where I turned down a shoulder.
The trickier part is getting the crank webs correct. So I drilled/reamed a single piece of barstock that was destined to become the two webs.
Then I marked the approximate center and saw cut the two parts in half.
From there I could index the hole locations and clean up the ends:
All this is fairly normal, the next step will probably send the "proper modellers" cowering under their bed in fear because what I do is so, so wrong. I weld it!
I pressed the ends together then plug weld the ends.
Then I put the two ends into the lathe to face off the extra weld.
So I have two crank halves. To join them, I clamped the two parts together with the crank throw installed. Then weld it up!
I assembled the engine and worked it in with the lathe. Believe it or not, the crank was about as straight as I ever get. After some fiddling with piston/crosshead alignment, I can turn the engine with my hand on the crankshaft. This was a big milestone.
I has planned on making two castings on this New Years Eve (flywheel & 2nd steam chest), but it's raining and to cast material today would be beyond dangerous stupid. So that's it for 2018...
...Ved.
...Ved.
