;D ;D
Hi Brian,
Well now, that puts a different light on the subject....... HOPE YOUR A GLUTTON for PUNISHMENT..... :big: :big: ;D ;D
The answer lies in the the valve on the ELMER engine.
It is designed with both OUTSIDE and INSIDE LAP.... I was hoping to keep away from that at this stage cos it complicates things for you....not that you won't grasp it, it's just a bit more difficult to understand what is going on.
The valve and eccentric dimensions shown on my previous drawing relate only to a slide valve or a piston valve which has neither INSIDE or OUTSIDE LAP, in other words, the steam and exhuast edges are in line with the cylinder port edges with the valve in its MID position.
I took a quick look at Elmers drawings and it would appear that his eccentric is slightly less in throw than I would have made it initially, given the port and valve land dimensions, however, I have not studied the effects of the angular linkage at this stage and this will most certainly make a difference.
Normaly, for a directly driven valve, the eccentric offset would be = to port width + the LAP, since this is the distance the valve would need to travel to fully open the port.
The total valve travel, to achieve the identical, but opposite position for opposing piston ends, would be 2 x port width + 2 x lap.
For an indirectly driven valve, (i.e. one not directly connected to the eccentric strap) then the length ratio of any lever arms or links will have an effect, as will any angularity effects, and therefore these must be taken into account. This could lead to the eccentric offset being larger or smaller than for the direct connection dimension.
The other major effect of LAP is to alter the angular advance of the eccentric relative to the crank.
The INSIDE LAP effects the exhaust timing and compression phases.
I have attached a few more pages from my articles which explain the terms and also shows the timing of a valve with lap.
This should get you thinking. ;D ;D ;D ;D :big: :big: :big: :big:
Hope you can get to grips with this.
Best regards.
Sandy
;D
Edit.... re-worded eccentric offset and valve travel statement to make more clear.
View attachment Fig 11 Slide valve sequence with lap and lead.pdf
View attachment Fig 11a Slide valve sequence with lap and lead ctnd..pdf
View attachment Fig 9 Slide valve and eccentric.pdf
View attachment PDs_ 5.pdf
