A Splendid result! - All you need now is to fit a series on magnets into the flywheel rim and some coils to make a generator... then a lamp-post to show how it generates... (800rpm will slow with load, but the cylinders seem large enough to power a small generator?). People call these "flea-power" engines, but yours seems more capable than that?
The original "flame-eaters" were huge, and used waste furnace heat (flames) to drive blowers to force the fires in foundries! But wore quickly due to the abrasive smoke and ash they were consuming....
I have a single cylinder flame eater - but the timing slipped, and I don't know the most suitable timing to get it running again. Can you advise please? (Crank position at start of valve opening and end of closing?).
Thanks,
