Hi
My daughter has a very expensive Tiffany silver necklace. It had lost a bit of its original shine so she asked me if I could polish it up a bit. No problem said I. Out in the workshop with a bit of silver polish the necklace, instead of getting shinier was getting blacker by the minute. At this point panic was starting to set in and I was in deep :fan: :fan: :fan: :fan: :fan: To say she was not amused is putting it mildly. A bit of research on the Tiffany site told me that they are factory polished and lacquered and should no attempt should be made to polish them. :wall: :wall: :wall: Don't worry I said I'll sort it.
Mike over in the questions and answers section asked about polishing in a tumbler. That sounded good to me so I set about making one. This is not precision engineering, time was of the essence.
A windscreen wiper motor and a stainless steel tin with a lid.
The wiper motor spindle has a taper on it. Drill a 8mm hole in a scrap of steel and counter sink one side with a large centre drill and drop onto the spindle.
Drill a 8mm hole in the centre of the tin and fit onto the spindle with a large washer.
Screw 3 bits of wood together to make a base.
Fit the motor to the base with plastic straps.
throw some polishing stuff in the tin. I understand ground wallnut works well but all I had was peanut shells. ( Hey I'm desperate, I'll try anything)
Place the necklace in the tin, put the lid on, connect the motor to a 12 volt power supply and switch on.
[ame]http://www.youtube.com/watch?v=PTJZYkZmM_Q[/ame]
After about an hour the necklace is polished.
Not perfect but pretty good and got me out of the s**t.
I am going to try and get some ground wallnut and try that.
Rich
Rich
