You connect everything and it revolves about 10 times with just a good flick.?
seems piston is too smallBut if I blow into the tubing I can turn the flywheel.
Harry
Don't mind about it..Thanks for trying so hard, I really appreciate it.
Harry
I think the same resultI wonder now about the larger volume of air between my displacer and power piston. It is much larger than yours and may affect the test you just demonstrated.
Harry
If the piston fits perfectly with the cylinder, check : the displacer rod fits perfectly with the displacer bearing ?and check the engine has gas leaks at the connections ?But the piston fit seems perfect, not sure how I could get it any better.
Harry
