Ok it is Dumore tool post grinder
https://www.homemodelenginemachinist.com/attachments/dumore-44-pdf.97647/
That's a good solution and I have a similar setup but got a few used Mahr digital electronic indicators off Ebay, about 10 years ago they were around $20 but for some reason they now figure they're worth $100. These indicators measure in 50 millionths and have only +/-0.02 range but I have seen on Aliexpress indicators with 0.00004 resolution(0.001mm)/0.0002(0.005mm) accuracy for the same price but with a 25mm range. Not quite as precise but better range and with a usb port instead of a proprietary port.That's what got me to making an independent dial indicator (post#5).
With some exceptions the wheel rotates so the nut that fastens the wheel is tightened when grinding, the sparks will go down when grinding externally and up, internally. Here is little more information Tool Post Grinder Resources | Dumore Tool Post GrindersHey Guys, A probably really dumb question but....... Which way is the grinding wheel spinning in relation to the work? Ken
Durrant? My thinking would be just to get finer adjustment, compound set at 45deg. And grinding tapers. My Myford has some wear so is I can hold a thou. I'm very happy.
@terryd , Thank You! I had forgotten that one.
I'll just do this without the face-palm gif
...last time on "Dazed and Confused in Front of a Lathe"
The sine of 5.75 degrees is .100(18806161) close enough
The sine of 30 degrees is .5 (exactly)
The sine of 45 degrees is .707(10678118) near enough
The confusion stemmed from that one time when the cross slide dial was marked/calibrated for diameter and the compound for radius. Sorry I don't remember the machine as it was at or near high school years and I'm sure my mind was on something else.
I've been using 5.75/84.25 for decades. It's a great way to divide a bit sharper . Imagine locating coordinates on a Jig Borer in radians....
Then the infamous 30 degree (29.5) compound offset.
Okay , let's just say less than or equal to by a close order.
This is .5 exactly. This turns a compound that indicates diameter to one that indicates radius.
Even on these pages that contain such fine (and appreciated) minds I see this confused and just wrong too many times.
45 degrees is 1/2 90 or ...
Nominally useless for most of what I have or will machine.
Then again I'm an amateur radio enthusiast and .7071 comes up all the time.
@terryd , Thank You again for that synaptic connection
The grinder I purchased new (1991) from Enco, back when they were around. They imported this machine from Czechoslovakia. So everything is metric. It is a Drukov Brno SBMT 2B. The one set of wheels for the main grinder is 150mm OD, with 50mm ID hole. I had made a hub that uses standard 1-1/4" surface grinder wheels, and I got some old used wheels that are 6 inch. I've seen this size on eBay.Well, there is another good example of grinding with tail stock support. The motor is elevated up & out of the way & the grinding wheel is of sufficient diameter.
- what is the diameter of that wheel?
- what kind of belt is being used
- what is the power rating & what rpm
I've also wondered about the power feed on a typical import lathe while grinding. When I had a distorted feed bar I was picking up an irregular finish. That all but disappeared when the bar was straightened & other alignment fixes, all factory boo-boos. But grinding probably exaggerates this if the carriage traverse isn't also silky smooth & true. That's encouraging thanks for sharing!
I spent the day grinding the taper of the spindle. It is very hard heat treated steel, and I only have the grinding wheel that came with the machine, some sort of gray coarse vitrified material. I need to research which kind would be good for this sort of hard steel. Then try to find one for the metric arbor.I assume you mean this wheel dresser? It was mostly orientated around scrap bin stock. The one included in the kit was a clamp on (chuck or part) affair. I don't have a (rotation) spindle lock so wasn't comfortable with any potential movement while dressing. It also never seemed to be in the right position so I came up with this which clamps on the bed. Still on my to-do list is some kind of collar under the dressing tool head so it can swivel around to different positions but still preserve the center height so the diamond remains tangent. I haven't skimmed off more than maybe 5-10 thou but seemed to work ok. Mostly its messy & I'm paranoid about grit so everything is covered. I powerfeed accross it while holding the vacuum nozzle to catch most right at source.
