Mine grinder uses a white aluminium oxide wheel mounted on a home made spindle. I would not take anything like so agressive a cut with that wheel. In my case the cams are machined to about 0.005" over size (on radius), hardened, and then ground, taking cuts of 0.0005" and allowing it to run almost to spark-out before adding more cut. Even with some cooling, trying to go any faster would overheat and colour the cam surface.
My grinder does not really have a bed as such, but is instead based on two pieces of 5/8 birch multi-ply glued together. This may make the construction clearer:
