An Air Cooled Tiny is under way.
This engine is all Arv's geometry with only changes to suit my personal preferences and tools so no drawings or other details will be supplied.
To make it air cooled, the water hopper was removed leaving a 1/4 wall for the cylinder to mount to. The cylinder was made of cast iron with fins for cooling and the head mounting holes were extended through the fins to the tapped face of the frame.
For personal preference, the flywheels are fitted with taper lock hubs instead of set screws for mounting. If you look at the split taper inserts you will see 5 holes. Three of them are to pull the taper lock into the female portion of the hub and two of them are tapped to release the male part from the female part to disassemble or adjust. All holes are for 0-80 threads.
The crankshaft was extended 1/16 inch one one end to better fit my flywheel as my hub is a little thicker than Arv's. This is for the side of the engine that has the gears. The other end was extended 3/8 inch to allow room for a pulley to mount to drive some sort of external load if desired. The crankshaft also has counterweights incorporated. This is really cosmetic on an engine of this size and intended RPM, but as I turned the crankshaft from 3/4 inch diameter bar stock the metal was already there so very little extra work was required.
The fuel pick up tube in the fuel tank is offset from the center line as I think it will be easier to install the fuel tube. It also let me use a close fit hole in the fuel tank for the tube as I could insert it from the inside and rotate it into position.
On the frame, I put an extended fuel filler tube instead of the threaded plug. I may put a cap on the exposed end but I have not decided on that. I will wait to see how it looks after assembly.
This how things are at the end of day 16 since first metal was cut, but there were 5 days I was not in the shop. Most everything up the cylinder head are machined, but will need some finish work done for cosmetic purposes during assembly.
Gail in NM
