The final prints deal with the exhaust actuation. Most of the parts are fairly simple and won't require any special instructions.
What you use for an ignition system is up to you. I personally felt that a small engine like this one deserved a small hidden ignition system. Most of the engines that I have built in the past used points and either an old buzz coil or a large automobile coil. Either way they are just physically too large.
My friend Jim recommended looking at the S/S Machine & Engineering CDI units. I contacted Roy Sholl, owner/operator of S/S, and he recommended the complete CDI ignition system which included the coil, battery pack with rechargeable batteries, charger, switch, spark plug wire, hall sensor & magnet, and all Futaba connectors.
After receiving the unit I made the base that would house all the components. I guess there is plenty of instructional information to install & hook up the system for anyone with electrical knowledge, but in my case, there were a couple emails and phone conversations between Roy & myself to make sure I didn't mess it up. I just can't get my head around electronics.
I started out using contact points but couldn't not get the engine to run. It was a system similar to what Jim is using and his runs very well. Roy is trying to figure out why mine wouldn't run.
After failing to get it running and not knowing if the problems were electrical, fuel, timing, or quality of the build, I then switch to using the hall sensor and magnet. I made a plastic holder for the hall sensor and mounted the magnet in the side of the brass flywheel. After adjusting the timing to fire at TDC, the engine immediately run.
