That's a way of thinking that I like.. In our special cases, we can do anything that works that would not make sense for a commercial product.
Technically everything is soluble in everything else at some vanishingly small concentration. But the severity of the galvanic effect inside a crankcase is minor as evidenced by the fact that aluminium pistons do not typically get destroyed by galvanic corrosion inside an iron cylinder block, even over decades of use or storage.Oils, while being "dielectric", and seemingly being insulating between electro-potentials such a different metals, can manage to carry ions of water and acids and still permit corrosion, Particularly where in Engine Oil they are exposed to blow-by gases (steam/water-vapor, Co, COs, HC, NO, NOx, etc.) and heat and dynamic mixing. Or so I was told by my industrial experts.
Even Petrol and diesel can carry a tiny percentage of water seemingly in solution, only to rust a hole in the bottom of a steel tank when left for a year or 2 undisturbed.- Without dissimilar metals, or electrolytic corrosion.
Anyway, I was once told by a Professor that the corrosive properties of iron and steel can be summarised in 2 words... "Steel Rusts".
