- Jul 16, 2007
- 3,028
- 1,119
Gentlemen, the next 3 posts are going to be just pictures. I have finished all the machining and wanted to share it with you before I started all the grinding and filing. I want to share a mistake I made and why I made it before the pictures. On the left side of the housing is a boss for the speedometer drive. It was roughed out very early on and I didn't pay any attention to it until I started blending in all the surrounding surfaces. While I was nibbling away around it I thought it looked a little 'off'. It certainly didn't match my drawings and they are very accurate. At this point a little checking was in order before I went any farther. The face of this surface is 34 degrees off of the horizontal. That shouldn't have posed a problem for setup, not like when a surface is 47 degrees and you're not sure whether it's from the horizontal or the vertical. When I put the protractor on it it read 26 degrees. What!!!! 26 degrees? That can't be!! How on earth did I set it up on 26 degrees? Nevertheless I laid it out in Autocad to see if it could be saved. I could skim the existing surface back to 34 degrees, open up the hole, make a flanged insert, press it in and all I would have to do is shift the centerline .036. Now I have to insert another clue into the story. Usually I set my jobs up with a vernier protractor, no problem. Just prior to cutting this surface I had just purchased a set of angle plates, 1-30 degrees. As I was resetting the job to recut the surface I pulled out the 30 degree plate and the 4 degree plate and set up the case for re-cutting. Hmm, something didn't look right, the surface was horizontal. Now that can't be! What the heck is going on. ??? FLASH! What happens when you put a 30 degree block together with a 4 degree block but turn the 4 degree block the wrong way? You get 26 degrees. Although it involved more work I was really happy to find out why I screwed up and that the part wasn't ruined.
That's my story and I'm stickin' to it.
Anyway, on with the pics.
