Nice work George! Looks really good. Would love to take a crack at this engine on my resin printer! Not sure if you need help by the looks of the other pipes, but I'll take the risk and chime in.
I've found the
Alias site extremely helpful. A lot of the math and most terminology transfers.
The youtube channel
36 verts is my go-to for theory. He explains the why and concepts transferred easily to other packages. I've done a lot less shotgun clicking and praying after binge watching... be warned though, it is cruel on the mind.
This is my typical workflow for troubleshooting kinks on lofts...
- Sketch planes for your circles on either end should point towards the guide or the work. Some devs might auto fix that under the hood, so maybe not a big deal.
- Profiles (your 2 circle shapes) should have the polarities match or there will be a nasty kink in the middle. If you drew a circle shape with points, both ends of the pipe should have the same amount of points (segments are called degrees) or you'll get failures and artifacts.
I think the above two are good in your example, the kink might be in the step below...maybe.
- Guide (the long curve run) can be attached tangent to each profile circumference, but the opposite side of the pipe will go off course down the road. Adding more guides sort of helps make it look better but still produces kind of crappy results. If you can use the circle center to snap your guide instead, Solidworks should support using that in the settings and your pipe should be uniform. I looked up the Solidworks help and they have a centerline option under the property manager. Not sure if your version does. Another bonus to centerline splines is their lengths are exact, so all your pipes will be easier to match.
- Remove twist if SW allows you to use control points. NX allowed me to in the example below.
- Another wild guess...it looks like there's a transition between the straight header and the curved pipes. Upping the tangency from G0 to G2+ might smooth the transition. Not sure how or if those features are connected.
Below are 2 attempts during break today using two different functions in NX. I could also use a third "pipe" command buried somewhere.
The left one failed by default as it tried to guess, but I just followed my usual steps above to correct. With lofts, we're always having to guide the math, which is why following tutorials has almost always failed me.
Or you can just leave the kink. You would get that in manufacturing if the walls were thin and not enough filler/sand was placed in the tube before bending.
