- Jul 16, 2007
- 3,028
- 1,119
Here's the last 4 pictures for today.
The first is just a progression from the last one. Just a tiny bit more stock removed. Once you get the high spots knocked off it's time to go to the files. I have several rifflers with a round cross section. They are a little over .125 at the big part and taper down to about .04 at the tip all the while curving back like a shepherd's crook. I use a #0 cut for roughing and a #2 for finishing, at least on aluminum. The flat surfaces are filed with several flat, curved rifflers, a couple with blunt tips and others with a semi pointed end.
Once the filing is complete or at least seems finished I start sanding with emery paper wrapped around some maple sticks of different shapes, flat, square, rounded etc. Once you start to smooth things out with the emery you always see cutter marks to then you have to go back in with the files and touch them up.
I save all my small pieces of emery and use them wrapped around pieces of stock for getting into pockets and corner.
As can be seen from the 2 finished pictures there's a couple of dimples in the surfaces. I have to say that when you're making several hundred cuts on a part, going up and down in -Z- it's almost impossible to not make an oops. These dimples are probably no deeper than .002 but they show up like a sore thumb. If I was totally anal about the whole affair I could drill them with a small drill, put in a piece of aluminum wire and refile them but with all the work that lies ahead on this project I'll worry about that somewhere down the road.
George
George
