aonemarine
- Nov 18, 2012
- 887
- 212
Are the instructions ready yet? Lol.
Ok I understand, I do have some imperial cutters.
If you are going to post a program for something small to start with I would like to try it, I am keen to learn more about CNC
Can I ask what CAD CAM programs you use
Thank you
Michael
CamBam I will post the code for mach3
I would be very happy to run a test for you on your engine head. I have a home build CNC (Modified Harrison horizontal mill and Mach 3) in Metric so could check conversion from Imperial as well. Keep going,and start a thread in a forum for each part or file for everybody to go to for answers. If anybody has a problem and finds a solution, then post it so that no back up required. I would be very happy to run somebody else's g code on Mach 3 ,especially if you run it through a simulator, but careful looking at the tool path screen in Mach 3 will give a very good idea if there are any problems with a particular machine/ driver/code combination problem.
Buchanan
I am sorry Steve
I meant "if i ran it through a simulator" not you. Bad South African English!I look froward to what you produce.
Thanks
Buchanan
