Tin Falcon
- Jul 9, 2007
- 7,207
- 789
In the process of Eric trying to resurrect the TB3 project there has been interest by newbies to get involved this is a good thing.
The other thing that was brought up was the possibility of a beginner engine with a small team say 5 people.
so here are some thoughts :
Goal #1 Have fun
Goal #2 Each team member have a complete set of parts to assemble and engine.
Goal #3 get less experience builders involved.
Goal #4 Keep it simple I suggest http://npmccabe.tripod.com/mccaberunner.htm
Goal #5 Keep cost down to this end limit team to continental US
Goal #6 Keep it open we can do TB4a TB4 b TB4c if needed.
Goal #7 time limit 2 months.
Eric and Pat not trying to take over here but guide. I can Coordinate a team if needed I have two runners built so can offer experience and guidance.
And some of these Ideas were from pat I can not take all the credit.
The McCabe Runner It is a simple one sheet pan set available for download.
A couple of the parts can be made with hand tools and a bit of skill.
There are only about ten parts.
IIRC no tiny screws to tap or thread.
Mostly aluminum parts.
Here is a pic of my first Mcabe runner. I built a second from acylic.
I used brass for the fly wheels and pivot plate but aluminum would work fine. I made a steel sleeve in an aluminum block.
Parts breakdown :
1) base Brassmachine
2) cylinder block piston pair and wrist pin : Steve Hucks
3) fly Wheels 2 per engine,Shaft Groomengineering
4) bearing carrier and rocker arm :Crispare
5) con rods, valve and rocker arm shaft. Pat H
I suggest 6 engines in case someone has to drop out with health issues and a sub needs to step in all involved still has an engine . If some just quits no engine for them but life sometime throws stuff out of our control. If there is an extra at the end the team can decide how it it is used museum display, roving show engine sold for charity whatever.
Pat this could be the team build lite you are looking for not an IC but a great little runner. If tolerances are kept good it should run immediately upon completion.
Goal #1 Have fun
Parts breakdown :
