After years of putting it off I've started building a taper attachment for my 12"X36" import lathe. I'm using this one as a guide. http://www.homemodelenginemachinist.com/index.php?topic=7086.0
I had a peace of 3/8" X 3" X 18.250" hot rolled plate steel I found in the scrap pile that I cut in half at a hole that someone had drilled a slightly offset hole in. I milled both ends and then cut a 22mm wide slot to match the way bed. Tomorrow I'm going to make the clamps. The "C" clamps in the pictures are just for test fitting.
