Rayanth said:Going to be heading up to grizzly this holiday weekend (one of their four warehouses is about an hour drive) And it was going to be just for looking around, but the more I think about it, the more I get the itch.
I've fairly settled on the G0704 mill/drill with stand, as my first machine. (pending anything else that strikes me when I get to Grizzly)Several things come into play in this decision, versus a lathe first, and it just seems 'right' for me:
- I am looking to transfer jobs inside the company to a milling machine operator, so the experience will help
- I don't have a proper workshop, so the included stand will help
- I was always far more comfortable on the mill than the lathe, in H.S.
- There's lots of neat stuff I can think of to make on a mill... not so much on a lathe.
- with a little ingenuity, many lathe operations can be done on a mill, as I've read around the forum and elsewhere (chuck the part and use vise as toolholder, use a rotary table, etc)
But I'm trying to settle on other things I'll need to get at first, with it. Obviously to some extent this will be based on what I want to make with it first, but there are some absolute basics that I am sure I will need:
end mills
mill vise
wiggler
parallels
v-blocks
flycutter (of some sort? Most i see in pics around here are nothing like what i used to use in h.s.)
DTI (?)
cutting oil (suggestions?)
some sort of chunk of metal to turn into lots of little tiny chunks of metal
anything else I should look at as bare minimums?
I am not expecting my first project to be an engine. It's been nearly 15 years since I did much of anything with true machining (not counting my present job punching holes in $140mln airplanes), so I suspect I will start off with an old project I recall from h.s., the snowflake-in-a-cage. Maybe some other easy stuff i see in project books here and there before i start working on mill-based parts of engines.
Inputs as always greatly appreciated.
- Ryan
Hi Ryan,
A good well made lathe could do some of the jobs that a mill would and a good mill will do some of the jobs that a lathe could do, both subject to size restrictions, but neither is capable of doing all of the stuff of the other.
At the end of the day it all depends on you and your budget and the jobs requirement and if you are going to make money out of production of these parts or if it is just for hobby and prototyping.
Take your time and make sure that you buy the best machine of either type that you can afford, it will save you money and time in the long run.
A.G
