Continuing on I have made the 3 Guide bars all straight forward as I have a surface grinder very easy to get them looking very nice.
Next came a real problem for me getting the model to run on air on all 3 cylinders looking at some other posts I was vey confused on what to do to get them all working on air. I noticed on some videos of others they would feed air to both the HP and LP cylinders and get the model to run OK. I could not achieve this I tried many things including making different eccentrics for the HP cylinder all to no avail, in the end I tried checking the timing after reading an article from John from johnmachines YT channel and ended up with a better understanding of how things work, not fully grasping what happens in a triple expansion engine but enough to try a few different things.
This allowed me to see that the HP cylinder was nowhere near correct and the fix for me was to set it 180 degrees from where I had it, I thought I had done enough research to have this correct but not so. The timing disc and bits were made using my laser engraver which can cut 3mm MDF easily that is how I make all my gaskets as well just draw in cad save as a DXF file and all done.
Great build can you tell me where you got the drain cocks from or how you made themLast for now update photos with displacement lubricator fitted thinking about a simpling valve so lubricator will probably be modified.
HiGreat build can you tell me where you got the drain cocks from or how you made them
many thanks
Hi
The draincocks of the side of each cylinder are standard from Stewart models.
Let me know if more information is needed
emers[
Hi BobSuper nice work. From your descriptions and photos I think I could take this project on. The method you used for the crank answered a lot of questions.
thanks for that andyThis is the method I used on the three I have done and they all ran first time, hopefully it makes sense.
Assumptions: The cams are machined to the correct throw and angles, check HP 30deg IP, LP 15deg and the cylinder ports are machined to the drawing and if not possible compensated in the valve.
set the cams to sit equally to the appropriate crank (pictures)
HP cylinder, with the exhaust/transfer pipes removed and drain cocks open feed a few pounds of air to the inlet of the valve chest.
Determine what direction the engine is turning with the expansion link in current position by turning to TDC and find the direction the valve rod drops (direction of rotation)
Turning in that direction only listen when the air just starts to enter the cylinder and make a note of the position of the crank compared to TDC now continue to turn (in direction of rotation) and note the position at BDC, these positions need to be equal, set by adjusting the length of the valve rod, just the one driving the valve.
Now move the expansion link to use the other cam, turning in the OPPOSITE direction repeat the process.
IP cylinder, attach air to chest inlet without moving the expansion link turning in the direction of rotation at TDC check the valve is DROPPING if not swap the valve rods at the link end, now equalise as before move the expansion link and repeat equalisation.
LP cylinder, attach air to chest inlet as before but remember you have now turned the engine round and last direction of rotation is reversed.
Hopefully this makes sense if not maybe I can take more pictures
HP cam setting
