Thanks Ben. I am not so sure if it ever will make a cut. Maybe for a picture put some chips on bed.....
Today I planned to make the cross slide. In the kit there is a piece of metal supplied, but I found it to small
Luckily I found another piece between my left overs and start to cut in 2 pieces with the band saw. First one side, flipped it over in vise and used a feeler-gauge to re-clamp the material for the second part of the saw process
The width is perfect!
Put the machining lines on the stock, put it in the vise, select a mill (10mm) and start to take the first cut.
Mmmmmm.....those lines are very close to the mill......cannot be OK. Stopped the machine and took another look.... then I saw that the mill was not 10mm but 12mm. I measured the shaft and not the flutes.... *club* :wall: OK, time for a coffee. Since this was the only piece of flat metal I have I decided to continue, make the swallowtail too wide and then solder in 1 strip of brass and on the other side make a adjustable strip. This little mistake costs me some hours to correct....
Finished the U-shape
After this I cut the swallowtails on both sides and cut a brass strip of 1mm thickness. To keep it in position during soldering I made 2 clamps from copper strip material, worked out well (sorry for the wrong focus in the first pic). After soldering cut it to dimension in the mill.
One side finished / repaired. For the other side I wanted to make an adjustable strip, but the cross slide is just a little smaller than the saddle. Will not work to mount locking nuts on the side. Well, in this case, no adjustable strip but a fixed one will do for me. This one needs to be 1.5mm thick. I had some plate of 1.5mm brass that I needed to clamp under 60 degrees. I do not have a adjustable clamp, so I started to look around to see what I could find. Then my eye catched my clamping set. The result you see below
Worked out better then expected, the material did not move for a 0.01mm! After gluing on the other strip I could cut the cross slide to length and clean up the front and back with a light cut in the mill.
Finally after some hours I have the cross slide mounted on the saddle.
It needs to get some horizontal lines on the top of the slide and a treaded hole to mount the axis to hold the tool post.
Regards Jeroen
