Hi Jason, maybe I mis-understood the simple solution of using shims? My understanding: Make 2 square shims, with holes for the big-end bolts, and bolt the big-end together with the shims in place where the big-end bolts join the cap to the body. Then machine/ream the hole to size for the big-end. Mark ends of the cap so it can be re-fitted correctly, dismantle, then reassemble onto the big-end journal. The shim material isn't in the bearing, just at the ends where the cap is bolted to the rod half of the bearing.
But add a drilling through the top half of the bearing so oil can be fed into the bearing for running. Even add an oil cup? Usually you can make one to hold a single drop of oil! Maybe even 2 drops? I have even seen oil cups that wipe of a bit of felt or string the gather oil that is fed down a suitably positioned pipe from a larger reservoir...
On an engine that was made by some apprentices in the 1930s, and demonstrated twice a year at shows, the big-ends had not seen enough oil (who wants dirty black oil splashing off a working engine on a public display stand?) so had about 0.010in. Play in the big-end bearings. I skimmed the flat joint surfaces of the bearing caps -carefully, after measuring the play - and when refitted the play was impossible to measure. It runs well, now, without the previous knocking.
