ShedBoy said:I am building a tool post grinder, I want to have direction and speed control so I was thinking of using one of the stepper motors I have laying around. I want to run it independently from a computer and was wondering if these two boards would do the job? The stepper I am looking at using has six wires coming out of it and is covered by the amperage and voltage range of these two units. Are these two boards what I need to make it happen. Or could someone explain what all the abbreviations are? The boards come from China and will probably not have instructions?
ShedBoy said:I have 2 steppers here which look the same, have the same numbers for voltage, amps etc but when you spin them have a noticably different feel. One is smooth with tiny little step feel while the other is very notchy feeling. They are made by different manufacturers. Is one better than the other?
Brock
Do not over power the motor, if it's a 12v Nema motor, give it 12V no more. If you supply more than the requested 12V the motor and IC will get warm. Also the IC on the driver board needs to be able to handle the motors needs.
RonGinger said:This is not correct. Stepper are current devices, what is important is that they are given the rated current. Driving them over current will indeed destroy, or at least overheat the motor.
A typical stepper driver uses a high voltage- as much as 25 times the motors rated voltage. It senses the current flow through the coil, and shuts off the flow when it reaches the set value. If you looked at it with a scope you would see a series of pulses of voltage. The term 'chopper' used to be used for thee, although I dont hear it so much now.
The reason for the high voltage is to get the current up fast. A stepper is a coil- an inductor, and current increases through a coil at a rate controlled by the inductance of the coil. But if the voltage is higher the current will reach its RL value faster.
I agree IIRC the voltage rating on the gecko 540 is 50 volts. I am running 36 . I would consider 48 to be the max.This voltage cannot exceed the rated voltage of the drive. The Gecko's are 80 volt. Cheap boards can be as low as 24. It is also a good Idea to place a large capacitor as close to the drive as possible to serve as a storage tank for surge current.
Tin Falcon said:with small hobby machines with less than 12" axis travel how much speed do you need.
Tin Falcon said:I agree IIRC the voltage rating on the gecko 540 is 50 volts. I am running 36 . I would consider 48 to be the max.
stevehuckss396 said:The max voltage varies from motor to motor depending on the millihenries. NEVER exceed the voltage rating of the driver. Remember this is a maximum and going lower wont hurt anything. The top end torque will decrease as the voltage drops off. All this information is on the Gecko website. I would check the site of the driver manufacturer for information and warnings before designing the power supply.
crob09 said:What is your Axiom here? "Ronginger" Do you have any video showing your work?
I want to see this concept put to use!
