Tony Bird
Senior Member
Hi,
Today except for the making and fitting of a condensation valve the port block was finished.
First the steam ports were spotted using a jig.
The steam ports were then drilled after which the steam passageways were also drilled. Some of the holes were threaded and plugs soldered in them. Then the steam/exhaust pipes were soldered into the port block. The inked lines show the position of the passageways.
The steam/exhaust pipes are arranged so they go through the port block pedestal's base and then on through the base plate.
A bearing pivot was fitted to the cylinder.
A spring and lock nuts were fitted to hold the cylinder to its port block.
This is how the model looked at the end of the day; not a lot different to when it started the day.
Make and fit a condensation valve next I think.
Regards Tony.
Regards Tony.
