Sometime recently I saw an article on building a spring winder in a magazine or forum, or? I cannot remember where I saw it but now I'd like to build one, any ideas??
Try looking at Antonio Fratticci on YouTube ie Utensile per Costruire Molle Parte 1/3. I Do not speak Italian, but I can understand his work. His videos are quite detailed and in this case in 3 parts including a demonstration of spring winding. I very much admire him and his designs, very clever in my opinion.Sometime recently I saw an article on building a spring winder in a magazine or forum, or? I cannot remember where I saw it but now I'd like to build one, any ideas??
I like your design and a collet chuck to grip mandrels of various diameter. I particularly like the ratchet idea.hello
I have built this little spring winder .
To the hand crank is attached ratchet wheel which allows interrupt winding anytime/coffee sip/
plus chuck for keeping spring core.
Head moves on linear bearings plus it has wire tensioner by which is possible
to tune outer spring diameter .
View attachment 134731View attachment 134732
Me too. I love making machines, but not sure I see a good reason to make something when the lathe works so well - ? Here's my first attempt with winding springs; worked perfectly:I just use a lathe.
Drill a hole in a 1/2" key stock and feed wire on a mandrel. Using the half nut on correct threads.
Awake,
I like your idea! I assume the tool holder screws adjust the tension on the two friction plates. How do you hold the friction plates in alignment? Can think of a way or two but not elegant, thanks.
I would have ran a screw next to the slide bar with a gear to change the distance of travel. Smaller gear with a idler gear to take up the space.hello
Awake,
Clear! I'm going to make one. The other designs are much more sophisticated but I've had relatively good luck holding the wire in vice grips and feeding it in by hand, by using the screw cutting advance on the carriage it will be easier to make nicely spaced coils.
