Job done !
I've had the entire system under 8bar pressure for 48hrs , with a gauge on it .
The gauge didn't drop a bit . So the repair was succesfull .
I had 3 8mm ( 3/8) pieces to solder .
They all soldered without a problem , and succeeded on the first attempt .
Here's a picture of an old one as an example , and a new one I made with a machined endpiece and stainless nut .
The stainless nuts are supposed to avoid the problem of the aluminium binding too the aluminium .
That is also the problem with the upper nut . There's no thread left in it .
But then I had a 12mm( 1/2) part to repair , directly on the condensor .
That would just not work . I ended up with either a blob of molten aluminium , or a joint that had pin holes in it , and was leaking . Ive tried this four times , and each time what was left of the condensor tube became a bit shorter .
No avail , either pinholes or a molten piece of crap . Re heating trying to melt the solder again and let if flow some more didn't work either . The part would just melt , the solder would not ! Tried both a propane torch and an oxy/ad torch .
So as t he condensor tubing got shorter and shorter , and my rods of solder also got down to the last one , I figured I needed to try something different . The product is advertised as being able to solder alu to copper .
So I made a repair piece out of copper/brass that I could silver solder . Then I flared the end of the copper to obtain some kind of funnel . And soldered those parts together .
That did the trick , altough the firsttime I also had pin holes , but reflowing it solved the problem .
The copper , with it's much higher melting point apparantly acts as a heat storage , and allows the solder to flow better without , or with less chance of overheating the aluminium .
So all in all it's been a great learning experiance , and I'm sure I will use this technique again if needed .
I've also ordered some flux , a liquid , that would allow soft soldering of aluminium .
Soft soldering won't work with the high pressures involved in cooling gasses , but there are plenty of applications
where it could be handy .
A quick word about my acetylene torch . When I started working , 30 years ago , at one of the major gas companies , there was a guy who was called the flame expert . A man close to his pension . He would go to customers and solve all kinds of welding and combustion problems . So I asked him can you recommend me a torch for small hobby use .
He replied by giving me and adress and said be there at around 8pm . It was his home adress , and when I got there he gave me a box with a torch . It was the best they ever made according to him , but it would last a lifetime so each indivudual only bought one . And so they ended production .
Take it he said , I'm sure you'll enjoy it and I don't need it anymore .
Bob , where ever you are now , know that I'm still using it and altough It's only once or twice a year , each time I do
I think of you for a moment . Cheers Pat
