Thanks, Dean. Gotta admit that I quite like the "look" too!
Tried out the fit of the exhaust manifold with the coolant return in place, and was not at all pleased, the curved pipes of the manifold were just touching the coolant return pipe.... not visually pleasing at all. so, faffed around for the best part of a week, made new dies for the tubing bender to try to form a tighter curve for the manifold pipe (in several sizes) and used up all the tubing I had on hand with no useful result... so then went with plan B, and put an "s" bend in the coolant inlet and return pipes, and it looks a lot better to me now.
This will change the size of the outlet pipes from the water jacket, no biggie. :idea:
That done, moved on to the fuel intake manifold. First up: cut a little piece off of my secret stash of 1/2" brass..
after a little milling & drilling, cut and bent some tubing, and here are the bits
Again used the engine as the soldering jig
and here's all the plumbing done to date,
and, couldn't resist sticking it all together to have a look
The fitting in the centre of the intake manifold still needs a bit to hold the carb, I'll make it to fit the carb once I've acquired one...
otherwise in plumbing only got the 4 little bits left to do that return the coolant from the water jacket to the coolant return manifold
Cheers, Joe
