- Aug 18, 2008
- 343
- 134
Gordon,
At the time Doug, and many others, built the Snow engine a company in FL called MJN Fabrication was selling all the Bruce Satra designed ignition components including the distributors. Many of us bought the distributor bases with a set of points installed. The four lobe ignition cam is an integral part of the distributor rotor shaft and operated the MJN installed points. A lot of builders used the points with any number of transistor ignition systems and a separate coil and battery. MJN closed up their operations about the time the more compact CDI ignition was introduced. Most everyone now seems to prefer the CDI systems using a Hall magnetic sensor in the flywheel or distributor base. They are as simple and compact as it gets.
Jeff
Jeff
