Gordon,
If you don’t have a pressure gauge that holds the highest reading, it is normal to see the compression pressure or vacuum bleed off rather quickly through the ring gaps. No flywheel bounce back is puzzling unless your engine hasn’t been run much. If you crank your engine with a portable drill driver and you can hear the compression strokes in the sound of the drill motor I would say the problem is not compression.
Have you documented your valve timing? I have gathered some relative valve timing information on one currently running 400 hp Snow engine and it is pretty strange. I have told two other builders about the 46⁰ cam profile and this single change produced a running engine in both cases (see link below). I don’t have a drawing of this cam lobe, but see item #46 in the original drawings and reproduce it with a 46⁰ angle instead of the original 58⁰ angle. It produces longer duration. Install the cams and then adjust the exhaust valve lash at about .002-.003”” and then, using a dial indicator on the valve spring retainer, set the exhaust valve opening (EO) to about 40-45⁰ BBDC and exhaust close (EC) at TDC. Then adjust (by opening) intake
valve lash to get IO at about 5⁰ ATDC and IC at about 10-15⁰ ABDC. It should run better provided everything else is good. This is not an orthodox valve adjustment means, but with only one cam lobe you have to improvise. The wide valve lash hasn’t presented and issues or wear on my engine.
Jeff
http://www.modelenginemaker.com/index.php/topic,4060.630.html (go to reply 632)
