Hi Pat, thanks for the compliment.
No cad/cam for this part, just a written txt file uploaded to the cnc, after all
it is really only a rectangular part with corner radii and some holes.
I have attached the program I used to make the part, note though there are a lot of "T17" tools. This was because I only had 3 spare pockets in the magazine due to running another job yesterday. Just do one operation then change the tool, do the offset and restart the program for the next operation.
Definitely not a production program, but for 1 part it worked well.
Bearing bores will be milled 1mm undersize then finish bored after the base, side plates, bearing caps & cylinder head are dowelled & bolted.
Andrew
View attachment O5700 RUPNOW BASE.pdf
Andrew
