Moper361
- Oct 21, 2017
- 50
- 11
Hi all ,I have just completed a small steam engine and am in the throws of setting a new challenge for myself .
I fancy having a go at building a small IC engine from scratch similar basic design to my steam engine I have just finished .
Basic specs
26mm bore
30mm stroke
Rod length approx 112 mm long
2 x flywheel at 115 mm diameter
I am unsure if to try with atmospheric inlet valve or mechanical on both inlet and exhaust .
I have never built an IC engine before and would like to gather basic information for thoughts on a camshaft that would work for either types of valve arrangement
I don't want to get to brain washed with the since of cams etc but want something basic that would be workable .
I would be working along the lines of a mushroom follower design lifter so a cam with quite steep ramp could be used as I can make a camshaft like this on my set up here without to much issue .and think this is more inline with what older engine designers used .
Any help or feed back appreciated
Regards Nat
Basic specs
26mm bore
30mm stroke
Regards Nat
