Bentwings
Being a long time auto racer the first thing that usually comes up is how much power does the engine make.
So we are talking steamers down a ways. How much torque and rpm do thes little engines make ?
there have been a number of home small engine synod built over the years . So what’s involved. Usually the first is the brake dyno this I’d a measured length bar with some kind of braking agains a flywheel. The bar rests on a scale and measures pressure usually pounds against a scale. There is some means of forcing the flywheel to beare on the arm. Various means of causing the arme to try to slow the flywheel a brake shoe. I’m sure many of you have seen these at farm shows with big tractors huffing and puffing . We go to one every year and it’s surprising just how much those big old steam tractor can put out . There are a number of you tube links for small engine synod often directed at go kart engines. But thee are just to big for our little bench steamers . I saw one years ago at the farm show that was based on an old hyra magic transmission fluid coupling or fluid drive it was pretty primitive but it works well . I’ve given some thought to a model dyno but load cells re still pretty expensive so I’ve started lookin at reflux’s coupling . I think a small coupling could be made that you bleed water into or out of. That’s the principal that many really powerfull engine synod work on . Actually Pratt & Whitney used this type to test the big radial engine during the war years. Today car engine synod are electric but some do use the water idea. It’s measuring the torque that is the tech issues so anybody interested in a desk top dyno?
