Low speed belt setting the motor is running faster.The internal fan normally blew the carbon dust away from commutator onto the insulating mount of the brush holders, thus shorting the surface ... Check inside yours. Also some of the clearances between brush holder metal and earthed body metal were less than 0.020inch, 0.5mm. And there was evidence of arcing.
The attached are an old photos of the original brush holder that had suffered a lot of carbon dust pollution and arcing.
View attachment 158157Plus a view of the replacement brush holder installed
Arcing had occurred between the Philips assembly screws (earth to body metal) and the aluminium of the brush holder.
Also on the under-side, directly from aluminium rivet heads for the brush holder to casting metal (earth) on the body. Photos are after the whole assembly had been cleaned of l the carbon dust that covered everything.
The arcing had caused the thyristors to blow. = expensive repair.
Diagram showing fault paths that short the Thyristor in the AC to DC bridge.
Explanation: The Live to + to motor to - to Neutral is switched ON and OFF by the thyristors, according to their trigger voltage. The wave capping of the AC input by the thyristors varies according to the feedback of the control trying to maintain a constant speed of the lathe, as the load varies. At very low speeds, the DC voltage is very low, thus current low, and speed low. At high speeds, the wave capping by the thyristors is reduced, so the DC voltage presented to the motor is high, current high and speed high. At a fixed speed, if the load is seen to vary, by a speed change, such as a cutting load, then the voltage is instantly increased by the thyristors to increase Voltage as a consequence until equilibrium of the speed is achieved. – This is almost instant and undetectable in normal use.
But if arcing occurs inside the motor, or the motor connection is interrupted by worn brushes failing to make contact properly, the motor slows, and the control turns-up the voltage using the thyristors. Rapid switching of the motor on and off when brushes are worn, or when arcing occurs (short to earth at a brush) will cause a voltage spike from the back EMF from the armature – which may cause major arcing, serious damage to anything else on the mains circuit, or cause sudden current spikes that blow the mains fuse. I have seen evidence of these damaging voltage spikes and over-current on mains devices on the same circuit. The original input mains filter had blown a copper track. The power board for the speed meter low voltage supply had a shorted track between the mains input soldered points. And a Mains fuse and holder had exploded with excessive over-current ( >30A estimated as a 30A over-current device had triggered => safe.).
If the armature winding fail to earth (as mine have) from overheating OR overvoltage from damaging voltage spikes, then the diode bridge is shorted and the mains will blow fuses. And earth leakage devices. And likely thryristors, etc.
I suggest you check and clean yours, if the same type of motor.
I hope some of this makes sense?
Dave, I use low speed setting. BUT that is a belt change, not an electrical matter.
What I am think the carbon from brushes is getting into electrical and forming a carbon resistor making the motor hotter. It something that is easily overlooked or may not even be seen.
If fan running to slow to move carbon out is where problem is.
The motor top speed is 6,000 rpm when spindle is turning 1,000 rpm .
So if turning at 100 rpm then motor is turning at 600rpm.
Fan was not designed for that Low speed to move carbon out.
You put all fans you want on outside of motor it will not move carbon from inside the motor.
