xander janssen
- Jan 5, 2012
- 183
- 241
Probably a dumb question but is there any way to make this sort of clamp that keeps the flywheel spokes in alignment, one to the other?? Easy with keys.
Adding more fuel in the "carburetor" improved things greatly.
Even got several minutes of consistent firing. Unfortunately no movie of that. This is 2nd best with an occasional misfire.
Not bad.
Not bad.
Intake is a ball valve that is held close by gravity and opened by vacuum as per Jan Ridders design. It might be a bit too loose in the seat i.e. too much vertical space causing it to bounce. Is one of the risks of this type of valve as Jan Ridders also mentions. I can still adjust the free space, so that is next after optimizing exhaust and ignition timing.Hi !
Sometimes it's not the carburetor or ignition...it's the intake valve, sometimes it gets stuck a little bit, make it a bit smoother (a little w20 oil at the valve guide or make the guide valve a little smaller...) and will be fine
Hi,Hi .
Congratulations !
And, next, how many cylinders will the engine have !?![]()
It is indeed a 4 stroke Diesel engine, at least the real ones as build by De Industrie.Hi !
Is that a diesel engine? If yes then I have an opinion - it's just my opinion of course and that's how I do it
Let's design and build a similar engine but with 1 cylinder
When you get it running, you play with it, test time and amount of fuel....everything...and as you get more experienced with diesel model engines and then you can design and build multi-cylinder diesel engines.
When I make a 2 or 4 stroke engine, with only compression, I'm sure it will run
But when I do diesel engine, even though I'm quite confident, but when I start making injectors, fuel pumps, ball valves, it almost goes beyond the limits of skill, experience...and patience mine
And honestly, my 4-cylinder diesel project is my dumbest project
