kelvin2164
- May 10, 2014
- 58
- 3
As a background, I'm bulding a 5" live steam loco and doing all my own castings.
Small ones are ok, but I'm trying to cast the body for the boiler hand pump in brass. It's about 28mm dia, 70mm long with a few bosses and mounting lugs here and there. (I would supply pics but cant find USB cable). I'm getting holes right through to the middle of the casting in the thicker areas. I've tried adding a large reservoir at the bottom of the riser right next to the heavy area, but this goes hard before the main casting and a hole gets sucked in right next to it.
The next item is the cylinders, 50mm dia in bronze. If I can't sort the pump. I will never manage the cylinders.
