rodw
- Dec 2, 2012
- 1,146
- 340
Re bandsaws, whilst there is nothing wrong with the one you've chosen, If you can raise the budget to this one, you'll find life much easier
http://www.machineryhouse.co.nz/B003
The reason I suggest this is that I took a second hand one like you are looking at home from Hare and Forbes and promptly returned it. I then bought the next one up new (it was similar but since discontinued). I wore it out in a few years. Down side is that it is very hard to get to cut straight (crimping a metal ruler between the guide rollers and running it up and down along a set square help a lot).
I then purchased the one linked to above. The green one is made in Taiwan, double the weight, has a bigger throat and is much better built. With a cast in back guide, its much easier to get to cut square. I would have loved to get this one http://www.machineryhouse.co.nz/B006 but did not have the space.
You are on the right track, bandsaws are much more versatile, cut unattended while you do something else and are soo much cleaner than a metal chop saw. They are also quite dangerous, I put 6 stitches in my finger last week courtesy of this saw and a 6 TPI blade.....
