Setting up Shop Questions - from an NZ learner
Another clamp for the table. This one using a modified C-Clamp.
5_L--mAHB3eAdlx-eDrgqjbAXNJAKLQLnMIOh5fC5Lf_4cH8I7V9Wl_LyyAr6dGds7iSwJYIOFyMMwkfLT1OR-OlLdnPcVqiu0gZAueQ4CxreypA6GM7LzxlxBS_omGqLKeIWi9Hypppk7zTLy9p1N6sOPyXieZ774favcCnimQABRENqcFIzc0PsjXYXcNDETTKle0PjLFyYbxnPYJScyqYX2W2nNdJOQwGWEC8XfBfLIOwP3PyjdxgPA5ieIWjMnsxRwvlZEnhynehIet54ELeOyx33aksbo35omWjnorYY820vbHOnUG9N5HIcPJiuz0iNyUGGXQnVyWupU0T5B8c4n9wAAUG7dRxrbrnhhhAMLBP0OzYy5q4vXLcDNC8acsmGaM3gV6wEeNuMcZzMk88koQDZnSYMbjcS77VoyYQLCK3DcssxX0NqFxIMqLtqRAJqyoF0GITa5CKwPoEANQujkiLogeW1pvUTwW-pQBXZqNSY1YhKuGbukT9ixJmHjSBIo5PDQoyXpaq5a1PezU7UxrwgOpGNvbsuHHOm2WfSsYjFHoHZT6Z275SniBAA_Mw2b53Ko9G_9pmIjdmjbmE1u_h-KfYZb1QZ8Y=w800-h600
ntAGmbBehLUpaiWx0KcwyP99Z6alUUsRvP8BrN8M1FKvu1r9mcA7owIwgXFqAenkCNVgUlnVkCUflOVlkjrpvXBt9IDgBRQXPZAfVSb3aYjG4fa7sHYXh7XofCifNWpe2A2UxWpmfFPhK15jgieqfE3MqUEfw4jgVwOvgUf3zcSHSqU_02kMNgyjC2aSQHUyQtxEWvcMOlaZXz-ffkPCwzrEqBsyWHFWHJi3JWYYPEBH_wZhKN2o58U5yLd4Ga-1r03bDb4zX40fXiYAkERMVdGfzH_Gxa-2X3zn4gfZjgKyu-YYYq6ADnPABN-Du9KuPzJR-Erf-bNsfta_tNhzzDx1_PV8n2jBZ1uXtXwD4kLZc_Xy41dy0wJE_Ph5kd3knqNNj1wO02-Ss-29w9U1JWeFkBiPT9qf6w6IUxNoOhgxmZYWMx8wRRYn-lXSRnFeLpCK5e7nyYfjpZTjKcm8ZWR09aQ0cqj_oyhGhxmYWYFsikNsYpnJrC-oCUN7kCh0QWMy7SCiopp-ruVC7z5c99YfDQC9Qq_WwsHTvr69JgMvgWoh0bqXQxZQ-9f7T6nr-Af17HAvwD-A6IejosRfMWJQ7RmbuqAfoKgHaiU=w800-h600
Ld6NI6A7bd7n290rIRdJVme55Q1tja73Wdaizxxg1VQhE4AgTDqB1vz1GcY4nH7OTl_dKi9a2WztrSw-L5gSgjLxBIhVi9ZEFRnKpCPjUnLf36hKeADvA4-9Jq6TWnzFS-Tl60YAe_6GuaOkAypV_Qey5HPyNN1Pu67j9r3uR7w2x-cpAMlFn75uZ_EJNvntrFoZ-A3IFBNAAMxDe74Alz02a2aUwuW3Rc8uvTH5eolK4X3xNYhQhYYP6RF49s-d_eZdResDI66_MPx-8U4Z51EitIE2GwuOHw0sYDkSYqP6saTGqFqQ9l5tLA5Whmod6dwILFqQA06lBY8aLX5JSQordb4Xp-_SdWfDV6K05i58KGbt4IbjuHp9dq44goo1tartud6m9WOvOzbgJiog4uEiSCjsVjD4IlPRiynqAXe_y7hulbpu6U0h-am7ZNnu9jogOVmTNEUU2-Y4hkVPRT_v3a6JvJCVdO4gahQh8SlftboezBZJxTshjtm_n5iQeR0upfxJdDUPCInUtT4UKU6RoBzC82WDJwe0Jo6u4VkwbLN6O8M0IbXFleAmxfuDttkzjihccHrMAB6RMpWPSdkI7RuPwlFAFx-i370=w800-h600
Table update - pretty much gotten the vice mount done. Some cleaning up to do like closing in the ends with some caps. But funcitonally it done.
The receiver fabricated from 12mm mild steel and MIG welded outside joints.
8_H7LyotPfGR5Z_xbnRU2rWQuJOzWX5-9RDgx1TpFvmn9CKfU5XG3fE_zHVYjvKONHBLUb1AUZ1IxhmfHDYnHNPqirP-HE-oUtwcVmaT30OCYJrG5Gs8QLHlr1qVhohFu0M_DghR38TB5DT_PKgCgEXpz8gedYJdhYDgjSg_9xS5hvWNYIXjx6UvuoeE-j-vWGR5e-EYvERpxn6hN9y5c8rbFLHNqu-GfUS43XR0g60pa2j8Ohr-0j9ce8zfwZFTm8gNOue4GcE2cuMiVTvKfjtvybgMZBd7anKc9K-mWZjbBMyQwuBTKQaUxZm8jFL8kKLuMxyKHNTpjF4FvKYb7WnlLp4DOec1VLNbAwapNS-F0sVR-MUYirALabMRAkb9RHzhorEB2zxiNk_LzJ-QefyF8EVRxBQjwXWdIlsrv7lSrnFX0Q7_9wFISctJtsh2WTJRwMOKOVk6vOjcpXYKeFybrPj1Fvb2PKJzPo_Vo-EG7SVTxVxeLpS2GoQmay7cf1W4_rB71HnFDTOquLwg-DWSzvpRbfGur3UOzRkeyLXpnrzxlLKZLazArWdY2raxb7fCuqCNlDms1Z8PKZNhQeFWfNP7COgIa_Ay6lw=w800-h600
Tacked up under the table ready to full weld up. After this it got a bit ugly. I spent quite a bit of time practicing and finding the correct settings for uphill welds. I got there ... sort of. Biggest issue was access to these with a mig gun was horrible. Couldn't see what the heck I was doing. The overhead weld ended up being cleaned up with multiple TIG passes.
qVJT-KaC5zk0Ra6fba0Hmarg3faBTwnWwUb_HDuygp8NHBl2s3SuK89_eDQjdHguKp5L3bSEQolwOYk7aBTphm7e6Flow3iSzVjnZpg36foo4xLYm6FqGNXZK4vTO-7JA_Q8JaG3qwcRSjXP_v5Fi99C_OLnIPpSnvRmr9sNCdo8RuldoSd3vQ9sWAvwAfrXzp5TxuZyVa2eHfv1R0Vzrna5JkXtu0UpWESqiRVhfaeIf6UlBqwmdwFBdjmrrzsiE8CX6j4NLWmnRnUCfchnb76LJWN_h1MU_6yfNNcMCpmyvVp7al8Q9UdCJY_zQgZmJ-VrFTd2Z2Hw9nW-72bvrm6PvhWP5PuOlrMeNQ9HRFPWv_teze2uSIZ77W2Ci6Jtyv9ojft6i4wQ2rihEMXEe-zchymKotLN3QN3zwXMnglgSDJodEgcD03aUUk8HOWeA2CHxzWATzj46UPi0kojdmy_M4VlYFiCQ93viSFhuZ4cM7Rz7RK6EJEmZyT-A9bHe-B6hDF9iw940tNe1RAoHzlhddDuIoMxZ9U8jKLkEpuE1MCK8jdS5m7L_aPJICHvPko3rJ_6yrA1JKtCPNDH0uVfl1xHwrkZI_wT3ig=w800-h600
The mounting frame for the vice tacked up and in place as a proof.
hE9Ko27D-weqVcHbJhcGmUtFgOA4d5UuuYRVASigkApeY5Bj4cId8U_rTU7jIv_e9PszKXNgGQdO-eSffqTYGGWO01zFBnngQ-dKqn9VC47uKr043Uu_e9hHeqZm_iuqPc227cyBESPTqDoYjT1KRFIWLQeZqrfvs2MEPwiKo_9i1QkkrFeoEZkQYUC4Qua1foZF01tmVTWF-QaFLsBPnlX9yJwQypR0N8YHSm0PzGQmOWVlogKgdN3x09DMJFPR4RW4VqSMIB6vzAgjetCYvtYY7Kv4yaxb4EcCxOVdn0osqhGLcE5FVswvoW_odHVkYsFSnPTgPa8_KTOB-ND2mYVm0LTGOPlh4xwpPZSsLpIyODBq-FwFws5pWN71O4SA16mZS9P51NEftY4Apchd7aMXTrRN9jsgPp2Dq6cemY34fb73KwVZIxNAfNMqqWH-SmGSqWThpF5Rtez6APNrpelsISn-3o7smLMLMl7e9Ven-6mKfjiDVKkU2kPWo7Fucz_cBUUaZd9leONbG_mZf-Y46-FcP8-7R77szHd7aEDCnbEnBdyC_hd61TZNZsZ1v0mqwlwPNn5bdx_QvP81pdlABYeVUDReXZOikJw=w800-h600
Vice mounted and ready to rock and roll. Of course if its in the way and I need to remove it then just unlock the bolts and pull the whole unit out.
gVZ5oWHpdIpxcpiES_1GR5Sk2z53jAAXf-U-_KXz-gB1KJNTG6-POaW0UUPcbNUVmo87jdobm-GmzhGakPEhhEQgMjRUFn8zEseSIHJtdAB9pW16oi7BouMpud4impeyzwqu1VwFJ46F6AAZuONTtiyas6eKv3g9_n4ASpKQQL4W2r4P5CBa7mLq3bbkkqYS3k3pHHtqgBtx4Xaa_CmNJL1ttLBoRqeHXtalD8TV3842sG6nSy97o2K_J8leRoB8RtFUCJV6pfsJOjgJdI9Mf0gPNM3-3wrw8CPJHHIsDO3TW26muwQ0ZrLuudsi1pE272JaaMIsZhG9nV6jHyfQl4aKM7hJzOAX6cKzfhuaSqBAaZFukVXyf4GkRMxy1shbBKEYYjOpIlmzcMVJL5OaEq901GcZshi1POhugp_pxdAwEOm8WrVjRQRVh-WkRhEY0PvVGYz-ciY6tSps7wAbCc4IZbBR2HEZUq6q8Fy4QxxSA5PEW-yGg1r6X05BoyiIzzBjHEG7M55aKuMtI4HbWMf_BFzZLFA3aCl1h7oAwvnG8SNpGRl6XtPZUMN0oauhQx15GwLcM3g0hzkNZ_PsnVtEZYpxjviV_NAxcTs=w800-h600
Showing the locking bolts. The plan is to add some T handles to these so they can be snugged up by hand instead of needing a spanner.
2zVVUfp6YEHGkyXmrOIbjug7zaQ70K8ktUxgkA8YnGLFKsc4-zVk9qwMczvC3nli0LZa8abC_yvE2y0nJb_OtDee74BowLTkP_PGB3WyZlj646otNXlGmx3u7K-z17to0cG0m9-8dNWUQoNoAQF-JfzhQZ090CzibPuRjzfhSj3FC0i9FG60NUG6L-0jUbdpgVUKgO2GNpb3-NYHEKgtM4UKuvWY64qXRCVUgTxdRjODk4aH7rbk6qwDfqCQ6GW7GpfkE78X7ayNgwF5_NmPD4L0_llDPv3UqGLdvs0vQKOLgySNH9IQpSBY-fqb4l6235H3bCOuvcjKaroZtgSinMaDQVIRKFKjiPbyF9nQkZ_E0SI0mSeqdlvA07-iHXaSlz-AOQjwKva1ix2TaM5yibhnvjOGThb2Lsj_YpcrZz5FhpNGYOe-o0qOipPm_AENmbAOknVLdRksE8SOQhocrnmA8_Px5SZUpX--Qw2HpXqfNWNXY5hiIEdj7Ci6o-JlIlrYRsI_3HXOd2aUbilOQu9U1yWaabsjU-zLTQESoOpP9tmOe91_WSX04sP7HTmXGPF4wjNJsD679tcT4v3LGrwgD0xiJk_URTT856k=w800-h600
One removable vice.
-DzwbmlnB9rUz0NP-jLNRtwNfr3WvV16LSO2ie6RRopQVWt6SRz-PYJxzn2ECN4Jrg6gvJylHQ_pKTGA27Q-DgpCp3YaKwCid_uXH4WJK46_hViEH6rmUBQCSlWphb9Vb962FUyms-PJLUr4DBBQP6bpRBWNvCjI6I8O7Y1QgWDrQmKk0_0Paa-eHzaJjG8XtOgPb-wUDvvzhfy3g9Xm8zUg-z49-6C1-Ad2NU_0-hEQU05pH9kRbQ7-Nj14Sw7Y3lfg9Ux4A2UGcJ1txGMrd53yE9FYjqMzdeqBmWTogHSV2bu2nGgMaDQ3dW-FtrEri2-m-LX5Q_s-PvegUWp9qPqegfBco_LoTgSD_h8eiMt2SuA_avB1Z-G6METnUvcOGkC0HlpYqL3QQ1Vg7JKSsgs5QXXxzzzDlPpkv0zhei2Mv2n7Zo4GQD_7oJnC2bNYNpdmCHw7ysElTt_WmhiM9q70X2eL4MMPzcHKJW4y8k7va283FXYxyVug0DwNY_D8h7y4mKBZHF86enMdT_raCQqGF8EHJl8mL1ohqxy2uhwASN1Avq8NgPnXfaBi1KKzOlIW6lljPTFqZcnG1R8LfRvuMeYGjzT8S-SbztI=w800-h600
James,
Food for thought from one shop dreamer-builder to another: I saw a YouTube video of a shop tour (Sorry, It was about two years ago and I can't remember who it was.) of someone who had a long bench with two vices mounted, one on each end of the bench and lined up with each other for long parts. If I was copying your build, I might put two removable vices in to do the same.
Me: I have brackets and clamps to add holding for long pieces at the "free" end opposite the vise.
By the way, I have been following your projects and I have to comment that your skills have improved over time and that your designs have become more inventive as time has passed.
Thank You for posting.
--ShopShoe
ShoeShop - interesting idea. Current experience has been that when I’m dealing with long stuff (ie as long or longer than table length I tend to be clamping things direct to the work surface. On this table that would mean a mix of F clamps or home made Fixture Clamps to hold things down.
My usage of a vice has tended to be in holding shorter work that needs to be filed, ground, free hand drilled, buffed etc.
I am intrigued with the dual vice idea and will have a snoop online to see if I can find some discussions on that use case.
Also, thanks for the encouragement re learning and getting a little “better”. I appreciate that. I am rather enjoying myself learning this stuff. It was particularly gratifying to have my neighbor let me loose with his commercial shop and forklift without feeling like he had to supervise me every minute. :)
James.
Started on the plasma table cutting extension.
Base frame built. I didn't get the welding sequence quite right as after welding up I have about 4mm warp in the frame between opposing corners.
7wHv3HcjU-y4meAVnpoXW7PQ0eTyF2pv119AoSacs41xBHw8C7b9Fb9C3-Lt4ztq_rvrF33fSsHYOKQFRXHy4zK1R__JO7mzdQbOl9U_AZZW3ik80C-NBTI5619mDB6863ChYGkhlIURJlL1qozKtpFqoKmzeMuKo-nh0qWIPSb37GW3lczHAg1jZxlwwpBLGEpgXhPakTW5PVUhGW2qwtUltNE2WvA1n0vI22YRSyWImoeG8yhSn5Rt0eIS5D6K4kNaNPeAEQA7JSBbw9Q5M1f71REiBNVUIv4L2l4bL0CQV6ETY2h5hFHH1nNFgZdP1su-VGvUI41IkMI81RWOFfemxUoDlQHKJwmnBC0O8NwNgfvkUFYbS91b6gE72hBMcmiFOW1Cg8gmZn7a-UhpIXPYJju6BOJLeP33-aYs-8fmtCDYSOSKiUmuem8Gh90cyvX-vCPx73_q9gS8jeF6woOfv4-m9g-TfzACNCBZIkfxbqrIOeK1782Ri85K_eqwYUPggIrYKenWxI_PkTxWHxvRuuKRrwv-twUGlfqc7uaDcIlCeD-seFavLAURdZ7r8-57rgDlLzsXLni-fX7zYAFkrt-yHSKFqlXOvhw=w800-h600
Added in the straps that will stop the slats from falling through. I had a good think about how this would work and the tensions that would be created. I figured if I did this right and had the frame clamped down to the table I should be able to lock things in and get rid of the warp.
VGwmeJd1mty7ArhyBrgCiufaVPNsF4XVUA2KChXiJzJvNJZC36y5fteuk-xsZrL9ySbBv5rdIAk4x74-dYkDI2d82lDTUF7la-bScyG2Wb83BKFXTP2wkfTIOeo-UrFPtb9K2IN-xJHXuZgptdVfYWQCH4XLCMVWnyrpqysQHZLGV8JoIzDBk4nV0flQeZ_QjHFVTM1KhR2z3ZsWYKUNQ6nYQ74GkLkex0l31Ja5Zh4xp7Ep43nuX0o7UXyrK52Blw3jMZbB-zIPgsPaxoTq6oA6WSMn773fLOaFAT87GBGfkhmD3UDyDZrjoVko_z1EDLDbhtuZ_HGYFpcOJ_MoYHEHZ424sHkGBYiWKHjyAPWnQMm7exuQwPhpOyxnDAHk_wlzUGU0UiyTDCfY3ZILtCRUCPdZyEhJecbOMEhcNdw8dpfZcXYnh1rGjxpHp3u-MDCfYROOo_9oc7Ejytn-AQfa3XqXfXgYSr7VpLjBwddinZGPB9dCmrGtNa9tXjutHEMvkbrk_UjHerQayah3H1dq2R0QSqBtTePbAsJBys5vjQjfxeuaRd3QN4u9ABRLoMdv-ncDK9p-Z_7AKHoW82pbaHeoq0thooOqXKs=w800-h600
Zja2V3JnBTJJu_znXd1ZmwXJW8V0FJB6IESaNBYu2v3jTRnb_21r_g04Ld0EmBNLcvVrcVNY4-eAkpwILTjUXVb3FvM_6pIBu_SJBKnes9gcD-YxvngFVEpxxELwkBL9dYcCJ4091pO505Z_fs47Tj_6-LBCG9WQkE37RzF7EhITVlYLW29exSYbFvp_bE4zDu20dlrb4SlsO89IucyBrfG9yH9jJwAuhYgPZXjEXf1Guhx5FPkyLYUqZ1hMB2A2UL_Z4nBVILo6iZkA-m4HhprpMzIHk1oSFWUkTQusQ3Kz2oHrVtsoRny5I1f1MZCOMw0U_RERlc_rY3BikpUpgpxk5xnwNIBeXrhR1-Jh-aID_6-njdolkx_SJHxPQQ4RQTKv5kejc3zVwrxHkm_c3kgvAft8N7AfOXCoirM3YVnipCnhwFpC1ufvfgBWOph71Fl3FDGBcQuDV0qQ97uR7fQ70EtawtgbbUvqvsUN8yFWxL1OiCgw3VbtJ1mgd_qsD99cCtl_7W0u5DA_Rk8APwvlTaXKJLFLXTmpcLwrCnGCZ071ImV9TYps4L9UEMAxCp5iTQvthD--wSprTJ-XFxv-lMmAS8k2wo_0I5Y=w800-h600
Net result is a table that is now dead flat, no warp! :D
Will post more progress as I make it. Only doing this after dinner in the evenings at the momement so not going to fast until the weekend.
James.
I have found that tack welding both sides eliminates the heat distortion. It's tempting with a jig or table clamps to weld the entire facing surface which introduces heat warping that even the strongest clamps won't prevent. Tack welding, then flipping the piece over and checking for square corners before tack welding the opposite side works best for me.
DJP - what you described is exactly what I did. The frame is bang on square within my measuring limits.
It was the flatness that went out of whack by a small amount. ie when frame was flat on table there was a small rocking between two opposing corners.
But as noted, all fixed now.
Finalising the plasma extension as well as adding some handdles to the locking bolts.
Simple addition to the locking bolts. Handles from 10mm round. Cut to length then cleaned up the ends in the lathe. A quick blat with the MIG and done. Really easy to use and large enough to get good torque.
h4wZk_jWjP-aVr9fJKDPcJiBmCmuWTt4JTPJxQpeD-yUv8XNFxm-R71w8oby5TZtoxvUzoxa2fRKI0-T6pKDWEXX9sTLkpKKCf-uUsKufYfE4VOKLrnmnh0FhUpPUdrKq8Mrdo8BTBR1dJws2wLuDYbDKxNWj98uNGBijH14Pc08_OleQ1yaa9Ic8t9kHVuWF7k3_NY9IOFE_bwGPakUr0Tro79B8Xh9drk5GXbBVfJYwCeOzbk0WWbW6ChZWKoT0j6LreKbdmgAqXaMV-p-xpDIo7_q9fLCaNyIZ3ZkG8PSxqmf4_Jb6-6XejTdmDa4URmjvbkaZYeXLdmPEL_0VwAiTEH8nEikjrp-UEbDPY-S1OJ98jTJlD0IBWjh7yBvA8q2QL6vgP3wAoE2U9Tt-UgjtsCKGwyK3WmDu4Gw6gqqidwex7E_PtzR8S64MBZJRznmbcT3y12pYQn5qWWHqhWVKICRG5pUlWOvTapxxyEyjPYXnLcxui9u1eDAe--FSrQBTPCtJC5LkDRQow0wR1c3Q_juRL6vCpdz0jVz4MYymrf5CRX_znrhRS_35dWEpP100ID1N2dShVbmzqBYMIiecciRnD3Y7LVFY0w=w800-h600
osA2kqssMjqBlgDe7JfeMjnbbIWjQq20urU7sBQ6R2Qy95FHcSFpb7lY8Tt_rmCkfdNJE3Qvi9bFSWA-B9MKqHDhpRqYwVlhmOoUB9I9k_GDY_2BdzHC6aXIlYz1MnaRa7hlrI9Fo7elecsiAHk2_G2_7Olrzzk8yZVhMzp9xJLMLrOzQ8QjCEBVjOGlpshY9oGtnKPlvpBBH_vUp1rYvvUTq-nt0zagNf8457vqoPOYls0frfG5KrprwGnY_oPO-Rof4OTFlFbfHp72dMERZ5fWtweTV4tBKjzjd4funOcDIHH1aXjHMDsJAW-dydbRs-BM1tOSV8v5OQziS3Jd7sUVkjvj1oKxPfaMambOeQikZSZzL2GC0Cl1jG2bSSiFp6ibglEaBU5Uh5zm5lpD6LjclEpv9fjmRNybokTqHc6lTfgFwUKu-N7wHpUtYfzkYHo-fxG6wmXSNfxP4Y8Fd3leqozrCvjlMT4HuJWLzp68Ruk86XPg_vre50t8WN0FgFbStNSkISXAf3lMSMWXn6JMGl74w1FK11cRxkReASrryK-gld4pDg86Ap_HdtJGT_fgiRpBtQiHhFBpcXQ7Klixx6RK-LKy07Ds-EQ=w800-h600
Started putting in the slats. Used 10mm rounds to hold the slats in place but to also allow them to be replaced. The box section is 35mm square. Cut the rounds 30mm long and the slats are 3mm thick by 40mm wide. So they protrude 5mm above the box frame. You can see the spaces I cut. They are 2.75 inch. That spacing with the 3mm thick flats worked out as the best mix without having way more slats that necesary.
0A1M6Qct6NGpLju96GxvayNPCaEd8-jC9Z0tSBEku5NTIrmTyPFSB1VgSqutO6iiu36iNXBlz9XhLldvmP6Ig8KPvZCbpJy9RXMmePoy9SyEEciv6HEWuHatCOrpAVnK1ESMMbhcn3zF1iIManHTSGhVSacI5tlzCtAZ4mjiRxs1eatj_2k8fmJdxhMUeOK2J8r8bR5LlLbKFE3O33f2NxuKGrC3qab9h1GMU4PoAzBVJDzKrgPuvlhg_AHeLUFrKQ-GQZgLIZLmY5jwIGBA-R2G4bBzFFogtLC_s_nTtRudCSWs6tLyJ8qzoJvGaJ5b6X4zyDvI136S9UDVBC2vBN7ZyrnXCGy18K3HbNu1WWkRDh1tjW1XBCTY5ChCo6W1R9Gccci-gaKRSX-uGTIxnzcQGX02BkWNw2beMU6eJDUOOFBaPWpsDCSUTEukBkSjMaZ_DtqIhET1zz1-pWiok6S3Smy_CjgByCZF6ORqLCZ8MkS_s2QAkOGk2O83gIsaaMLiZA6Q1_fzvEvMfP_qmuuPKus8hDMUR60mwyYrVCAaN39Mo1atQHb3duTr7P3oqrJ9i4mbxylAprGRPZQ3S1LwnixAiSQTlw_bJ5U=w800-h600
All welded up. Next stop is attaching it to a receiver.
lAlunKi2RQA479w7s8m2jhW63F3OijtKLPXMfOQAaXAaIeuYy00hjGFrJa7YpyUiZfPxsZuQVFE9gMELfsx0Y4ClWM-p25JxXun5rjA6cfn4eanXklppsi9zpc2MURxj3RaMFQ3zQ3sc7vwe5mjmXlAwEieQrVzW76FWN7XsGpMSPAqshxQgcS8r1UgBqLMXxWVxb-YWgNWqmxxoizQtvUT5bHTxxD-7asoFnDh_k2vMDgGV7t0gbhyPyFXm5N4pmoFFGBt36U0dy6a9JkhFi2CIe3KsQrHtc9Wh0LxPCGbSE7diIAJ5HopugjZjpQr9j8ncWz1UGcDYTDJNu91iySY6RvaLYQJDBRxsJoTfMEBl1RVT-_sGD6pnF_BaiDhTDReKMgoRcu4Ky1o6wEzCcQD8TKqEBdZ2BwwVV2MUY1c0Izzx-txfzvFSXvWzr_GyzgJTI1luoA26NtWCemIy6MHZCJVJffsvd0M9R6T8-y9oTpbVq77K9ohHlMzxNskSEjrL5GojI7Z4zRuqZnKrKlH7hFH1BRxPZ2PQtBzCyhGy6haCGw1h3_eNyfxtWE8BkO_HzsAYWAdppytOk9IoAwZY-QJbI6wJhciFzAY=w800-h600
The bracket welded to the receiver and supporting the frame. Its made from 6mm steel so should be strong enough for this job.
KBc3_MgaynGNN4Hh7XvmCaJZX8Uvhuu7_pGfa1iIatRDBqlxhl3bcq2thdLwQ_AVahnUPyop4_HnZbiWhwZ1YiXF7oUHrupB8xkhnsRrH89RX9N__l3ZlvzIpiVwxpPrS7wPdD5P67BGgSq3Wi3WikWv08EGd6nMrbpIs1c8ynNOCFkxJ6XsmFVEpyXVtK1GR_rz4cBlRbuRKcw_yGT46GPCcX5xDC4fQmGdHQrgbqW63vf9Xotcbkj5eYkfWEUJV6ImidWdkQEEEa8EPpREBnEMAjfb1IBArJ1xfCsBb0anLwMP04RSbyMM7cFYkN0kfQdhupjKRr1dnVQ6wgB1KJpnBQOOGIVOanOKNJQC_8fSI6LKVsCEmu8b3F02_hYqHdbaoZt4Eh4a4YJdgONCSDFJ1TiN3YiJzul77SMsiQyCEUHjmh5I0ck46QRfcqjjq8oi_KxrkEQwJHxRifhDFFTB2nQPgra3GLXwwt2-IDqi8vUen6A95AaEYaLGQbSBIElFrnPinKDROq2RkxG0A-W159VL9Q-1A6ObaSQEM8Lm-SH8JOIXoBgHGwiYPtPDGG4tplPg0kwQncyA-G7PHxb3M_qw9rOhgwnETqg=w800-h600
All done and seems to be sitting nicely.
coSeGTJQRaRiMJX9LFEocVNm4t_PPcxw1v2PZclW-Uo5y0DUJGN8t8zi6h6UuO9096YZxxXDQV8GzfbMhBip5l-s3WQGL9m-Ie8TrTmu_ZzQXEDCzfq54aqMRmKKbq2Ic-FAgkQwjI1lPL1XL4To8dkeBTyT4ohpV8fhEv4QvZUk-0PZunHTnJNZJW3HV6LkTmC_GJYmVVwpt1lfqiJMNfnb174V7m9rvaFiGg-Qo3kpwN5vPf-L3jS8Wz0cXpRFiY568j4ScHVtBL2wOr7Unlnmt66PhifMsEnno2tOINJstcAPjV90nyDOjaTPMQOjzfAVD9wfZQOS0PlxjRmv8vOsDWoT4FEZw8iGEMmA4ZWdackW0KLfYQuJUTiU3cJF2tKsUQq3ZfDIC8vCuXb2YYVAtIYE6Kc9np8mxXcbIHnk-MUt_KuFO9wAbCj-9z5uh08dfSVQ8zMdqMWHftL94RUmAB6MZM6KNvBX8aRNnQQo_Obgt0y2ejLL9gxpnuI-0CRUa5ZPByULSzW5NpDR4xxnwDQSDkxvlLmZo4ocVJghhlraxWM0YL8dwSuYvZncIQpII1T0Ooo7WRyluq1Q-OgNHO9_rRUlQBGM_WQ=w800-h600
SqCMbHd8PGrjo1c9XFtV4XIu8q85psGEnIFBAXn2Xd8kln_ldgNHzy_SVBc865OSfrbsIYDUnSVhlz7pBb1qPRZKE0YJuTwM2CH-gcgXwJZ1sUUhbI0ii-CwItLk5Sf5dH6ceDfHLUWAs9BXIP34IOJEoKTqDfZOlhcoLLXITdzNAFBwiGMCRr0uFHEkE9Z7nLufCSnwUXVV-fhodiiTEMhBbLNa19I2dgYHgexZdXEQRs6kWHTNlNma9WoFerZiTIz4o0Km08dRx5Uu0PkGvNipR7fwuORIPoC8skXfPREV7JpYJnTiJFwOF7uJvjAnrzOllvFykJLP3toGqeXU_xTEnxU2bw7IEnT2bksUD7aXObPtBEsOER5R-wHbKvwJYE7iyFjZbnhvucTKlrMYdnd8LoMkcPLMnAOHvkD0lvMiqKhNolqqgv3VMRrvL_cjSf590Mr_EqOo5rafPN5BLfAR6go2GSldHzj8RglH_s-DW1SwzZOKu0bgiRSdPxhREf0M1M3Y45eoRXxi4VgBsSTyA-QdV-xGecEIe1ivRPT2pq9cahwIXsVfpAUx9gBQn8_lNdWWdpTuloJlNN8PS_1NKULlUhACsqY1_9w=w800-h600
The current storage spot for it while not in use.
Iqgw-q1r2W7dlEPn9qwrp3zWYTQiLQGIk9tQJeG7NASor43dJubnEu5BbQLYHcFasTxXZIuxTixMc55qAlCtTfD3pkpcYxnzcQdwljnKBjLHm4HoloJnoaXYoVzZzyVx9Do_AnK6vnbo3KBFuy6-wLXFAbSBJC6zdGhNwkhhEibNcuQ4jaWHieZA5SUH0mdLca9xfUCeVj4Fq1FJzmycnm1so8qxQRptrzG2MvfTQJ62rVSTaGb56QYfb9dOJcy4_M14Sko0puzqCtbwI5nHSweQt4KsdWn4DM1AwRypaBGR_2OJWfevCo2lEqVbBVAbR8jRTFRweb7Dq72vAZbLGwfPLcPEatpCF4Ym0kTQy_w3lxrNBiB3sGvqIRZO-5LP1OINnePVR_3WurIY5bG1QUucczIdL9lVhAile0fMWtx2psS-iRksKUySH6f-jlljtnExNRAag-qudJJ9h9fUT70hZ9FpucmfSVbBv419HwHwB2FhMiWr2D-O4vgDwHPxGWvdN00c2KOi238AukojG78NjeFzOGqlzl15BLxbFrTWa_lSST0Ne8HzYhQjZQnt4bvJQb1zfjXkAd-z3InGrnZ7u1S_9LJdPa2ReQ0=w800-h600
All in all a good little addition. I have used it already. I actually cut the bracket pictured above on the table while I had it clamped in place as part of a test fit-up.
J.
Just catching up and good to see you included a removable vice. But I just can't understand why you did not turn the table over to weld it in. After all, that table can't be very heavy ! ;)
Seriously though, I seem to remember sticking to a 10mm top so I could lift it but even then it was bloody heavy!
I hate to be the one asking this question but what are your plans once your shop is fully set up? Will you start a welding repair business? Any plans for subcontracting small welding jobs as piece work? Your equipment may have excessive productivity for a home workshop.
As another project suggestion consider lining your shop ceiling and walls with barn tin. The place will be fireproof and easy to clean. When I insulated and lined my shop with tin it was cooler in summer and warmer in winter. That's just what you need for a production welding shop.
Take care.
I think the shop setup is the project. :)
It’s very close now I think. The only thing I would really like to have is a small surface grinder. Problem is finding something that is in the small class. There seems to be more options on that front in the northern hemisphere than in NZ.
I have a couple of things I want to upgrade. Like the MIG welder for example. Just Cose I want more options/capability and I can afford it under the “sanity for life” clause I have with SWMBO.
Projects to do include internal combustion engine and larger steam engines (size capable of powering a small wooden boat. CNC the small Mill, portable CNC plasma cutter, eventually some powered model vehicles steam and/or petrol/diesel. But I have a lot of learning still to do before jumping into those.
I might do some small paid work for people wanting stuff done but that the local businesses are not interested in as it’s too small. We shall see how spare time and motivation effects that idea.
J.
While my TIG machine is not a bad little unit one of its annoying limitations is how it treats a pedal. When a pedal is added on unless it is of the dual knob variety the pedal will always do 0 to Max (200) amps. What you really want is to be able to set the max Amps that can be dialed up with the pedal while having the pedal giving you increased resolution across the new amp range. I suspect this circuit does not do that in a linear manner but the simulation does seem to be delivering on the capped amps. Will keep looking into things.
gofvl_xPNtTwgnh5k2mX3umDwBhYOPjNjxCkvNM028DyIzwhDuIMQKluppCX7gKGiWlco2oBMZ_SELceCadeOA4uUUFd6-lFS3NLiPZ7vVLwITHQQl77RUS1wjHnTahhQlTtLVa5esQSJwvbt6_bLGfWfTXHcGwcFTv1ZsZW_uoZ2tDPyfa73yD6vEu4TofCHEEEVdcwuKtefEcMgNxoxYDsYBdApmGGDSrs2nET4Rd_fbtznDNnUp2JEv4t_Y9tsXffX-_XDZhfEHRyuX-kYbdAPNb00aTt3BdwGPXd-nS-LB4F-PB_Wy0tyqzriXGxhDG3afFzGSmcYO5yeldqa3b3VD2U4HB8WSgzXVHZvuKR33Wd4QroA1s4tzqtF_I-ytmwEM6fs6xrovnm5i7pXsUvFQ4cyUwQ-IEjD2sd3YiPZwejNxxrNvuWzZaP0QVCZ_FKVp5SrLzUoYNvXl9a-OSlLs3HyG5KBSIxnw1sozVSIolc4P3MHi22JNjlcqgLMx7LxYVGHd1BK04GDN5IlsyXYNHyujFP-sh-9HOVmz4Jd031ysyVH_CGTOeb2NYWcAv5V5f7gYkisFPkcwnQ3P_HV--_SBz4djG-EtA=w800-h600
Big call out to Bruce who fixed my previous and very flawed circuit attempt.
4wT5-CxKCn0PwG8ktcvCwDecrvcqbRlqdrzxr2yKBeHJLkTXOkvsRkVBvPIaXV6b8tC7dYg64rBkX3sMgS5FACuKVlSXkoYNcd2XBukL1KbUgOgdSuP6SYSr8Jqo9RIR8QWWRocGlmD6zSvV_Gp52D15vuJEKhytLZ6ez2iYVbdExJFo5UUDCAUh44ff0bXzcmr_Uf2V1W3mrQCCHILnsxCpitwc22EA3-UsO8_ko1GwLPyWe6f2GuzqwxfyH-l92dsR4b4q24foe3ejzslqeyCLHm0cMzs6ziFYVh_5GEWhhzsEIRXtOxQH7rAgKcBrLC253EECiHFVOetPICOWZiLVSMwPtM9acsSUzVhnMmXyJQ4ZT-HUhEqHUOiWivQv0wRWMdgdJrst-o9jypp-GeMFe1aLizVdtLVQMro8z6iNuhiHEg99ETjD902MmExBdn_xYHIgRlEJSr97IMEpZrR3KAb78CiqdCLsusUBWUx31ppBYmf_a9xxWzoAZlzk5Zw9EtMLbI2nCKp4-RkTYRdxBmPe1fZyzamMWLNSJnLxipfPLCT1pEQS6i3AGdN79pESsp0QGqM4EWcpZN2Y-MF0BwY4gjfd-ElaCwo=w800-h600
https://falstad.com/circuit/circuitjs.html?cct=$+1+0.000005+9.001713130052181+63+5+43 R+144+96+80+96+0+0+40+13.4+0+0+0.5 174+144+272+240+320+1+10000+0.49010000000000004+Resistance 174+416+96+512+144+1+10000+0.5099+Resistance g+576+96+608+96+0 r+416+320+496+320+0+50000 g+496+320+528+320+0 x+158+254+222+257+4+15+Pedal\sPot x+383+79+498+82+4+15+Max\sAmp\sControl x+421+348+491+351+4+15+Fake\sLoad w+240+272+416+272+0 w+464+272+464+144+3 w+144+96+144+272+0 w+144+96+416+96+0 w+192+320+416+320+3 w+416+272+464+272+0 w+512+96+576+96+3
Hmmm ... slept on this and did some quick measurements this morning. Not convinced I have this correct. More investigation needed.
I did some more tests and figured where I was going wrong. This should be the CORRECT circuit. Next stage will be to splice in a 10K pot and check it out with some welding.
Or use this link.
J.
    16.9 KB
So I have implemented the test circuit and checked how it behaves. Looks like its working as expected. This is just a simple test setup. Next step will be to splice the control circuit into the control lead in a more permanent manner.
6T5QzmWs37Td4pfPRFNjlF5PjZH70g3BNzK2Dhnjptc_ovdS7FgURL0oNxM5--UlXoEcyi_rpqQYM_sbSPk5dVoC9CogvCQoJCqUBjXf4ZK2siB0F4Xt_PjpOYaoGlzxrST3CCzLQy3rLVQtL3OYEfti_hqtWJ_G5bS8BRyQNNksCoIf5irYaaUemt5wDFySL5Zl-hEDpk50wR9xF8Mi7Y7ZZvTVeiArTuYCpKvBwXJSoxjklZPOmkfAoGzlU-43hWBFHew6OQBiSh9OpouueZm5XuGDmiKQ7oC3-nUEJCJXqt4uAAldjLAMxsGf2r8SkQUEQ5OczZv6oDVNG24_URzDIxztf5ZWTAGJURQLk7v6j1k0PxxbgXpFLFzEIdExLS1FiFtXnrw-rlBXUNL9-me8AApJ4EdULuH5aYvJIL8augUX5hMvG5v6J6hueMz0kdUu8oqi-Zo25tQK7M9iqeHIILzK-5aE8atYemAcNf7boRt9N2Uct7QGCUlrqTElX6UIlqzO5RD14oSF1FGKN96yf6T234izI2tKQNis8KJJWY4_K2cjI3QDeIPSleqZX52pM9Y8xX11Gk9-ms6U2kC6sD75PAJZ8rI4-WE=w2880-h1628
A8SbjRQJtmjp4XVbxOI-_ys_kOVW3u6kXLQtuhH4-rnGiQttBvVLh8P0Lkc00q0xbA2Xwrl3_Qa_G5N2flZGMXfg8dNVUSOnrF95FNTeB6FC_KGjBC1cKU-gJgyNsOGuvl5DUXqiQiuUNO1dhWW1pfV_L-XAbfJNUTi2Hz6TG48m_Oidu-Wi7C9y39TXCnL97j6ijH-AwDwGE542TPXZkq_88z4uu38bMI-JF7QWR_LJZ8T5dD6B_cXT_YrbILqWMUJs3zwWcY16MQi6DW08zgVGPZna90IoTZf2Uj84CzCUAvCai8TmM3tGmOqJi8Fd_CW_9ZglhJb0IV0Z8degCjL0XGqdpsuUCpexqTGK2QEEknHDHGjVfv3-b41xGr9MzxDMwRhVq0DKFuqNu-B1L4BL7AQLxqjoBPVTkIxilkslbyuiQDYE84RaGrBrTbNAfD99s_F5eidljKxzNCbcOu---azmBabQqadB9lHeGP32COu7J1ue0sgZcNLgORL-vaEblDGh901la1gbRlGLTrZWZvIRSft2k3pEkd29Ijgbqv10esMvxecePpsWBrCF0RtoW7XVlNUolzQJdHIp7S_aO55zIdi7LgZuOuU=w2880-h1628
jwPdFeSpxYeKDgc1txkrrh6skhfpl__aill2RjxDSrUmfdRt4Qz4nIQtsWkDYpMDX2kvOZ-XH4KAbm5tU0SIadhqDgHN3WR7N-M3PgjJTat6bUzFTQdUnYxl9i8eWJlRvWqONA4AysRui24pofzpmQrmqSUegw1M3rFbmQ__555foSYpkxBXrF-IQZy5OW0qcTHgJD4r1JvyFczJmkv9i17RnuSC7_gbXV5tRFzvTW0KM4CYXu-lDy5FlJHU9B84vvtjZ36E84ktZ8PBusa6camVsZqXGi87a6SpBjnWC1aEChzJuhObBcfxkdrssHSi4DUuK4s-o4lyMwVxk5hSk7bl-6qDwQZWOwS9GvPt6rftkvbuUiaDzzevzrNFWRD8pMjHy0ckZfBwBLpwUoCari8Ff-ddW-FZsbl-FQaA4lvSL55qY88JxELXGbTQMvG-Ea3O3pBN0PMou7WVlkAotVZT1sO1-Pu1FoN4rxr976OnGnJpkA4S97es6Y3styt-yw42vDWV20-h5oLM2h_zm6H70ClBEup9RSXSiYhz17_kBfLGljlXJq1YV50Toe5Zhhhcn5e8F3QTpMBAe_N32bAt3UvbYcE5wAo6qNU=w2880-h1628
J.
Finished the max-amps control box on the TIG pedal today and successfully used it this evening.
Finished "soap on a rope" control box. The switch essentially enables/disables the pedal by allowing me to stop the internal pedal switch from activating. So when in the "OFF" position I can push the pedal to max and adjust the peak amp setting that flooring the pedal will give without having the welding activate gas and the HF start. As you can see I managed to rip a bit of plastic out when drilling the switch mounting hole. One of those blistering four letter word moments. But a little superglue and its all sorted and perfectly serviceable. If it ever breaks completely I think I will replace it with the aluminium version.
t6dp4SbpfUJyJXX5RfXTAANTTj8jxtPw1pMZFt02IT50m04_8hkUZe2HVHdYoxvAAbjkF2X5mUPXlNakZenpG5fS-357FIEqWeeRA2gHmvJ2WW5rDHymo7xrsyiTH88N7HpPuyphQ9ZfONl3VH2ue4FvpGYI-p7eDUEqaXNcWImbtW6sOsBmSK2vj_SBF6QSnc_sQv3tRhYiRa5pGnVA8k0qiU7NuqMFAof2-bpZ9VOdjVI0mtdmvsYmvjOQ8AjjGk-lD0wO7ofC_C7ALMbl9UFebgscxiH-0K5jBP8c6HbnEkR5XIgn8Mj-A38yYUX1DNuME59AYgfDdTZSK44NhdMJQtjH_5u_dGVbd5bdioMcqeNDuFRtG--PmRWRTy4NTtVzLx-tB6y1gEXLh17hN7yyxpIFljQs_VB6D2OZZ2flwsgflBuj6wOA3ag8oD5rxSHaV9Kpur1_6-T41Fl7_AUVrwIobkOWmGLvbvux3H0FvqKVzfznMNlwHiNg8prIwrJp4YgJ0sQZUr12Evf6n6T6DiYe7zrTRvhwdEfNw3xgE2FXPdM7igRB7Yo0FggLWhXH9krKHH_YbD7qRsAnD6SDNlP1M1A2nYEem84=w800-h600
And the overall look. :)
8775NrO-OqIERffD2qa1ozy6O-YbpcoAa7KATjeU3pgmqvvUh6H2tIan8tqMnuKofDL_blH4z3FmD_WLxH3rq9dTdNJOZvmYQzfhdijJQiQQtumYp_5xKxsnTreMp38xH-0HuR0ww3ZGPnIf9nMXGIHUAJh7VXsjiKRDsADIIQoMWC9yjnGCy8PyEvpgP3djCs9fDeGpeUMXFa_pRRTjyfZW2-Ig2TqsUEJH_YkFeJeHkQ8udvaQAQa2PC5m8nV1VjMhVTxC5e2Ra_wtQqaeaYM3FT_MIIfDn6zvFzdn2pIF8b3Ng_o00xHzgf-RGe4kEmlZW7e0Rn22ElS0UaNqGQodkM-1amngqxGhGOFnM-Qtu8-1jrb6ZYBkm6B_DyvicWWbEc5AD42OFVl0g--UwwjKit5_x8V07ERCli-VJCZ9B9-hPx2yEIaqRemYStQ6Gq9OddWqW4df_3Sn4cnGs_Y3v9FO3GjscRHX1hW6Lr43EmTMuli1OYm-RMc7c6D3c6miLsfsp8IBLOJpxZDaySSlxwJwOObDx5B5vQufqrGXtDcGULVRvx4p3HdNz4BrGI-RL5JdsSjg-kTGu1I0KP5vtdPzw6FXyIr4gGI=w800-h600
Ultimately a very simple mod and for anyone with a Wave 200KD machine well worth the effort. You could probably do the same thing on any machine that has the maxamp limitation.
J
Well done Joko-nz, I agree that a die cast aluminium box would be a good idea. Those plastic jiffy boxes are not really up to rugged workshop conditions as you have found. If just drilling a hole breaks a chunk out, imagine what a falling piece of steel, like a hammer would do, or even the effect of the box dropping onto the concrete floor.
Ropetangler - I’ll probably move to an Ali box at some point. But given this is 90% of the time hanging in space per pic it’s (fingers crossed) unlikely to get smashed between the floor and a heavy object. In the meantime I’m going to enjoy having the control I’ve seen others just assume exists.
James.
