joco-nz
- Feb 21, 2016
- 568
- 209
James, you may want to think about using a seperate switch rather than the NVR on/off switch for the auto-off. If something goes awry it might not be a good idea trying to press the red button and have the saw drop on your finger. A heavy duty roller micro-switch in series with the NVR would I think be the way to go and put the NVR somewhere that you can reach in an emergency.
John - at the moment I'm avoiding doing things that required new holes or the cutting/redoing of wiring as that will void my warranty. This saw came with a 36 month warranty. Really don't want to do anything that could stuff that.
Anyway, I have a plan to put a hydraulic cylinder on the down feed so, in theory, I shouldn't get into a situation where pinched fingers is the risk due to the saw dropping.
However, in the future a cleaner wiring setup would be desirable and your idea would come into play at that point.
James.
