Its been a wet day here on Saturday with some other jobs getting some attention. But I did mange to get some machine time.
Pic #1 & #2:
First off I needed to be able to put a chamfer on the ends of the knob blanks. Up until know I have only sharpened the steel on my Diamond Tool Holder. Given that style of tooling and the supplied jig rather simple stuff. Today I embarked on my first free hand grinding of some of my HSS stock. So with a 10mmx10mm bar of HSS I set about making my very first, from scratch HSS cutting tool. Now for you old hands this is probably all pretty trivial stuff, for someone who last tackled metal working pre High School some 30+ years ago, its a case of "holy poop, I hope this works". So taking into account the numerous videos watched and some real life advise and demonstration by a kind soul I set forth. These pictures show the results. And I am pleased to say it worked admirably. Main shape of tool ground on the white wheel and the used a fine oil stone to get a final cutting edge. I remembered reading that its only fractions of a millimetre that accounts for the real cutting edge and that stoning beyond that is pointless, so I did that, saved a heap of time and seemed to get a good result. See Pic #3.
Pic #3:
Blanks with chamfered edges using home ground HSS tool.
Pic #4:
Then it was on to making the knob that is closest to the clamp noses. This knob will be trapped using a pan head screw. It was drilled through and tapped to M6x1 thread using a bullet nose tap on the lathe. Power tapped at 60rpm with lots of cutting fluid and it was a breeze. Using nice/quality HSS taps makes a huge difference to the crappy carbon steel Frost set from Bunnings I got early on.
Then using a parting blade sunk it in 1.5mm to get the groove for the trapping pan head screw.
Then a bare kiss from a countersink on both hole entrances to make a nice clean finish.
Pic #5:
This is the high knob at the back of the clamp. It will end up with a hole through it for a tommy bar. This one was blind hole drilled to 11.5mm. Bottom tapped, again under power on the lathe with lots of fluid by with the chuck holding the tap spinning free and using my hand on the chuck to provide resistance and an effective torque break. Once the tap bottomed out on the hole it the chuck just turned in my hand, giving plenty of time to kill the lathe. Then the lathe was put in reverse and the tap backed out. Nothing under stress, all at slow speeds, no drama and a lovely straight and clean bottom tapped hole.
Pic #6:
Over view of current state of play. Next is to machine the knobs for a grip profile. Not having a curler yet I am coming up with alternatives to this problem See pic #7 for plan render of what I am looking to do.
Pic #7:
Render of the grip approach for these knobs.
