vederstein
Must do dumb things....
- Feb 26, 2011
- 931
- 776
Drill bit wandering? Been there too many times....
Thanks John, I wasn't really thinking of solar power on Mars as I was hoping they might have had a bit of coal, after all isn't that what the Rover is looking for? Cheers, Peter.
Final assembly is a nice time when it comes to building model steam engines and this was no exception. I had been away for a week in Dalby Qld in our camper and this gave the paint time to fully cure. I’m usually such an impatient bugger, most of my engines have a fingerprint or two embedded for posterity. The inlet manifold tube from the governor presented a few problems due to it’s tight run, this was overcome by adding a short column and drilling a gallery to bring the steam through, I added a part of a casting from an old brass lamp as a bit of bling. The connecting flanges for the tubing were difficult to make as increasingly I find it harder and harder to work with M2 fastenings. All this tubing was soft soldered, as were the flanges. I don’t have silver stick thin enough for really delicate work, in the future I will correct this. As can be seen from the video, it runs quite well. What isn't apparent is the leakage around the valve face, not really that bad and I suspect that it will bed in over time. I tried all sorts of seals but the design of the valving makes this tricky so in the end I gave up and elected to go for a metal to metal contact, time will tell.
At the moment I’m working on the project as a whole, that is a boiler with all the ancillary bits producing steam for this engine to drive a DC generator to make enough electricity to illuminate a 10 watt globe, the final cost being just short of a Mars exploration Rover.
Back to the bench, and thanks to all who commented,Cheers, Peter.
View attachment 118833View attachment 118834View attachment 118835View attachment 118836View attachment 118837View attachment 118838View attachment 118839View attachment 118840
