Flywheels for model engines can pose problems as far as getting the right material. At op shops and car boot sales I always keep lookout for cast iron weights used by the keep fit members of the population and that is what I had on hand for this engine build. The first step is to turn a mandrel up out of mild steel and press fit it into the boss of the weight. This now allowed me to turn it in the lathe and face it off as well as machining the rim. It’s all a bit of guess and go as sometimes the cast iron can be so hard as to be un-machinable, however this piece turned like butter. The finished size came close to the plans, that’s always a bonus in scratching, and I parted off the mandrel and bored the centre to take a 12mm shaft press fitted.
Over to the mill and the rotary table for the spokes. These aren’t hard, providing you don’t make too many mistakes. If you do, like I did with the miss drilled holes, plug them, machine them off and put them in the right place. Expect to do things wrong unless you make flywheels for a living or have done a lot of them, there are many opportunities to humble the ego.
I fluted the spokes but then machined them off as I wasn't fussed with the look. A bit of work with the file and I was happy. The shaft was a piece of 12mm bright bar and I press fitted this into the hub with a bit of loctite 263 for insurance. This assembly was then returned to the lathe for a final skim across both faces of the flywheel and the rim, if you do this it guarantees that the shaft and wheel will run true without a wobble. (I have built some terrible wobblers in my time until I resorted to this.)
The main shaft pillow blocks for the bearings I had already made, along with the bearings. I certainly didn't bother to make them as drawn in the plans as they seemed far too unnecessarily complex, I just turned them to size and fitted them to the pillow block. Later I will loctite them into the bottom of the blocks.
The whole arrangement turned out OK, it is especially pleasing to see it rotate so true. At this point the engine was really starting to take shape but I knew the greatest challenge lay ahead, and that was the cylinder. If I had realised just how hard this this would be I might not have been in such a good mood, thinking that possibly I was making a bit of progress with this hobby. The thump you hear in the next post is me coming to earth. Cheers, Peter.
View attachment 118458View attachment 118459View attachment 118460View attachment 118461View attachment 118462View attachment 118463View attachment 118464View attachment 118465View attachment 118466
