I find that the more engines I build, the less they need to be run in. No doubt this is a testament to the fact that my machining abilities are improving with experience. One of my favourite engines, my twin horizontal which was built early on in my machining life was so stiff that I broke a silver soldered joint in the crankshaft while attempting to "run it in" with an electric drill. I don't personally see anything wrong with "running in" an engine with an electric drill, so long as the engine is free enough that it can be turned over by a hand on the flywheel, and everything is kept liberally coated with oil during the "running in". Speeds should be kept low, and the running in shouldn't take more than half an hour. ----Brian
