well here we are 10 or 12 days latter and we finally have some thing to post about this project ;D
the cam journals were bored about 5 or 6 years ago and they were in the wrong location, so i had to fix that and this is how i did it.
first i had to re-bore the 2 outer cam journals in the right place. i squared up the upper crank case in the mill and re-bored them.
for some reason i only took one picture of the set up so here it is.
once the outer cam journals were in the right place i then made 2 brass bushings to fit in the holes. now these bushings will guide a 1/2" dia. piece of drill rod.
the drill rod will be the boring bar (held between centers in the lathe) that will bore the inner 2 cam journals. this engine has 4 cam journals.
as you can see in the above picture the crank case was held down by two 5/16 bolts with a piece of flat bar.
the rear bolt was threaded into the cross slide right were my rear mount tool holder goes. the bolt in front of the crank case was threaded into a plug i made that fits into the hole were the compound slide would mount. as you can see the crank case was set up on adjustable parallels.
here is a shot of the set up.
this next picture shows the boring bar and the cutter i made out of a broken carbide end mill. the end mill was 1/8" in diameter (i never throw broken end mills out)
now with all this set up done all i had to do was bore the holes.
the boring bar goes around with the cutter and the crank case (bolted to the carrage) goes back and forth while the cutter bores out the cam journals.
now with that done i bolted the crank into the lower crank case
then came the upper crank case with a short piece of steel in the cam bores, for the cam gear to fit on.
next came the crank gear .................. i was getting excited by this point
and then the cam gear was put in place ..................... holy crap it all fits
now with all that done i think i will make the cam bearings and then i will start on the dreaded cam .................. oh mr steve huck were are you, paging mr cam shaft maker extraordinaire
thanks for tuning in guys and mr fellows you are very welcome for the tap idea, but i cannot take credit for the idea as my good friend mr john crook told me about it years ago.
chuck
