well i planed on having the rod bearings finished the other night but family things had to be taken care of first.
so tonight i got some work done on the rod bearings ;D
i soldered the block together and had to find the center of the blocks so i could chuck them in the lathe and machine the bearing hole in them.
i did some lay out work and scribed center, then i had to center punch the blocks so i would have a reference to set them up in the lathe.
well my eyes are not that good any more so i got out my trusty optical center punch thingy (shown here)
i won't go into a long and boring how to use the optical center punch lecture, but i will show a few pictures of it in use.
first you use the optical site piece
once you found center you remove the optical piece and you insert the punch and whack it with a hammer to give you your center punch mark.
part all centered up in the four jaw chuck and being faced off
bearing hole drilled and then reamed to final size
the next thing to do is machine the outside diameter to fit the connecting rods. so i had to make an expanding mandrel to mount the bearing.
so i chucked up a piece of steel and turned it to the id of the bearing block, then i drilled and tapped a 3/8" bolt hole in the end then i split the mandrel in half (length wise)
now all you do is thread a bolt into the end of the mandrel and as it turned in it will cause the od of the mandrel to expand.
here is the block mounted on the mandrel
i did not take any pictures of the machining of the bearing so here is a picture of it finished
now all i have to do is heat it up till the solder melts and i will have 2 bearing halves
here is the con rod and bearing almost finished
sorry for the long winded account of my adventures but from the start i thought i would give as good of write up as i could (i wish i could explain things like brian) showing the good and the bad. now if some one see's some thing i am doing and has a better way of doing it.........please by all means step up and let me know as this is just an account of how i do things.
if i have not explained things clearly just ask and i will try to clarify what i did.
thanks and good night folks
chuck
