What is that bore measuring device? I've never seen one like that. Please, teach me something.
Grasshopper
Grasshopper
Hi,Nice one Woffler. I would have suggested a liner - that bush sounds like a simple accurate and practical liner for the bore.
What pressure are you expecting to run at? Maybe you could have simply made oversized pistons? - depends on the minimum wall thickness after you managed to clean-up at 1.25". I would be very careful with the interference dimensions when you fit the liners. The interference develops hoop stresses in the iron body - which is liable to crack or split completely if very thin. If the liner is a "just-about-tight", or sliding fit, (rather than needing a press to fit) then it will be secured from moving by the end caps. Loctite products can help secure a liner - but the wrong one will cure too quickly and may lock the liner in place when "half-in and half-out". So be very careful with the sizes and check interference fit tables for a fit closest to sliding, rather than risk breaking the cylinders. Remember, the bronze will expand more than the cast iron when you get to "steam temperature" - so that also adds to the hoop stress trying to split the cast iron asunder. Having done the calculations to prove a designer picked the wrong "fits" for a component fitted to a car engine block, (Differential expansion and contraction causing cracking of the outer component) I have first hand experience of how this can easily go wrong.
I think for your "fit" I would check calculations, fit tables, etc. Then check the bore ID and liner OD, Hone the bore to suit the fit dimensions for the tables, say for the tightest sliding fit on the liner OD, and then fit the liner with a drop of Loctite added when the liner has been slid 3/4 of the way into the iron cylinder (Only if you want to add any Loctite). As a lad (1960s) I fitted dozens of liners into diesel engine blocks - after boring and honing the block for the correct fitting dimension for the liner. Then using the hydraulic press (Never a hammer/shock loading!) could "feel" the liner going in with a stick-slip motion - sometimes almost a "groan" but they were cast iron liners in a cast iron block, but were secured from moving by the cylinder head, so an "easy" fit was ideal. Anyway, we had to re-bore the liners to size after fitting to get the size, as the liners were always supplied thicker-walled than after finished boring. But I doubt you should need that extra process.
Keep up the good work!
Grasshopper
I certainly would like to see some more detail on your device. I see the general concept but it would be nice to not have to reinvent the wheel.Hi David,
Sorry for delayed response. The device is home-made.
Not my design, the original appeared in Model Engineer magazine some time in the seventies. I did not own the magazine but thought the design interesting so scribbled some notes and sketches in my notebook and used them as a basis for the version I built some time later (changes to design occurred to fit in with locally available materials, contents of scrap bin, etc at the time)
I can post you some better pics and some drawings if you like.
All the best,
Ian
I would like that as well.I certainly would like to see some more detail on your device. I see the general concept but it would be nice to not have to reinvent the wheel.
Thank you. It turns out that I have a CD that I purchased some time back with back issues of Model Engineer and it has that issue included so I printed it. Not sure what copyright issues are on these.The original design was by L C Mason and appeared in the Model Engineer magazine for January 4th 1980.
Do you have any drawings of this, please?Hi,
An issue that has not been mentioned is the fact that the external appearance of the bore would almost certainly not match the internal dimensions.
I am currently working on a cylinder casting and took the picture attached:
Dimension in the middle of bore used as a reference - dial reading 100:
View attachment 123030View attachment 123031
Dimension of bore mouth - reading 40 (60 thou, 1.5mm smaller):
View attachment 123032View attachment 123033
THe reason I write in bold, it's so my almost 80 year old eyes can actually see what I'm writing.Grasshopper, would you mind awfully, turning the bold off?
This is an obvious casting defect with both castings suffering from the same flaw. The core is out of position in the mold. I think they owe you a good casting. The only way to correct this is oversize the bore as another member suggested, if there is room to fit all the other bolt patterns. But boring it out will take a lot of work. I think if PM wants to keep their reputation they will rework their castings and it makes sense to be talking to themHello everyone , I am having a issue with a #1Pm research build ,the cyl. bore casting is way crooked before machining , it looks like a egg from left to right and the other end is not bad .
My concern when i bore this thing it will put all the mating parts ,cyl heads and everything else off of position and i not even how bad the bolt circles would be .
I went a head and bought another one and it is worse than the first one , any ideas for me to work this out ?
