- May 27, 2010
- 2,999
- 1,171
Hi Baron. First of all the main block and the tool holders are made on steel: I dissuade you to use aluminum! It is too soft.
Because the locking system is based on dovetail slightly deformation, the main purpose of the recess is to limit the contact surfaces just close to the dovetail 60deg angle. Last question: originally I though to put a small hard metal plaque in here. This is the reason of the 3mm threaded holes.
Hope my poor English is clear enough...
Cheers, Mose.
Hi Nicchiom,
You are right about not using aluminium,not even the hard grade.Some hobby
machinist would shy away using steel. Given the good sharp cutting tools,bar stock steel is really not difficult to machine. The Dovetail cutting is a mystery
we have to go thru. After two female dovetails and two broken dovetail cutters,I have sort of picked up the know-how.
QCTP made of aluminium will not last. The dovetail fit wears off.
Todate I have made two QCTP.
